Question about Ovens
Where is the bake on the knob? - Ovens
    Top Expert:
  • Ovens Master
  • 33,322 Answers
There may be no baking capability
Posted on Dec 12, 2016
I just moved into a house and it came with a ge oven the but it doesn't have bake or broiled written by the knob how do I know which way to turn the knob
generally bake is the up position and broil is the lower position just try each way the broiler is on top of the oven and bake burner is on the bottom.
Nov 09, 2010 | GE Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Bake and Broil Elements not working, all top elements are O/K and Elerctronic read out also O/K
Hi
Thanks for using FixYa. If neither the bake nor the broiler heating elements heat, but the range burners still works, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for manual", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kenmore Ovens
The broiler works but the bake side wont heat up but does warm
Hi There
I have found some stuff for you to read and hope this will help. Let me know how it goes.
It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Best Regards Richard
Dec 30, 2009 | Ovens
Kenmore oven does not go on at all.
Nov 20, 2009 | Kenmore Ovens
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Err on display when I try to set the bake temperature
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Jan 08, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
