How do I use the copy function?
I put the piece to be copied on the top but nothing happens
  • 12 Answers
SOURCE: copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Posted on Apr 03, 2008
  • 41 Answers
SOURCE: Scanning function doesn't work
If it copies fine, then it IS scanning. If you are trying to scan to your computer then you will need to open the program and follow the instructions.
Posted on May 28, 2008
SOURCE: copying files
I apologize, I do not understand. Can you please tell me what do you mean by "u3 system"?
Posted on Nov 18, 2008
SOURCE: can't make copies
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Posted on Jan 22, 2009
  • 1219 Answers
SOURCE: I put new toner into machine and it will not copy.
It is problem in laser shutter, call service, cant help you over net is complicated
Posted on Mar 06, 2010
Trying to install copy of microsoft office 2007 and when cd is in nothing happens. What can I do?
Its happening might be because of an earlier version already installed on the PC.
So at first you need to take that off and then put the fukll version onto your computer
1>Click on START
2>In start search type APPWIZ.CPL and hit enter.
3>It would open the programs and features window
4>Locate the trail version of MS OFFICE HOME AND STUDENT which is generally shipped by HP.
5>Right click on the trail copy and click on Uninstall.
6>Once its done, restart the system and then try installing the Ms Office from the Cd that you have.
If then also it does not work and the normal cd/dvds are working then the cd that you got from Microsoft is corrupted and contact them so that they can provide you a functional copy,
Hope this works.
Plz rate if helpful..
May 14, 2010 | HP G60-230US Notebook
Black line down page when in COPY mode on MFC-240C
You need to poiwer cycle after cleaning as the scanner only calibrates during power up. If all is clean, even the white bar over the small glass assembly, and you power cycle the machine and it's still there, you will need a new scan assembly.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Copy will not work on printer itself
The 1150 is not a stand alone copier, the only way the copy function works is when the machine is connected to the computer and the program is running. I never liked that much here in the repair shop because in order to service it I have to connect to a computer.
Jul 21, 2009 | Lexmark X1150 All-In-One InkJet Printer
No booklet came with my lexmark 2600 series
For color copies, you press the function key with two pieces of paper and color dots on it. For black and white copies, you press the function key with two pieces of paper and black dots on it. The link below is to the user's guide for your printer. Page 17 shows a diagram of the function keys, also, page 39 provides steps for making copies.
Lexmark 2600 Series User's Guide
Jun 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Copy problem hp 6310 all-in-one
Instead of pushing the Ok button you should push the "Start Copy - Black" or "Start Copy - Color".
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Plain paper is coming out with black lines on it
if the lines on the copies happen only when you use the doc feeder then you have something on the small slot glass if you put the document on the glass and make a copy if there is still a line it is probably the drum
Dec 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Line on copy
You have a small dot on your scanner glass. Lift the lid and check the thin piece of glass on the right side of the machine. The smallest piece on the glass will cause that. Clean if with some windex and a cloth and the problem will go away.
Jun 30, 2008 | Sharp AL 1631 Copier
19 people viewed this question
