Question about Kettler Exercise & Fitness
I have a Kettler Olympic treadmill which runs well until 9 km/hr. If I increase the speed over 10 km/hr, the treadmill stops and gives error code err7. What can I do about it?
    Top Expert:
  • 8,204 Answers
I have a Kettler Olympic 7892-000 treadmill that has just stopped working.
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
Dec 31, 2016 | Kettler Exercise & Fitness
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Can i increase the speed of bike by alterations
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Chinese Taiwanese and Korean 125cc Motorcycles Repair Manual with four...
Jun 19, 2012 | Atlas Tiesse R 50 2T Motorcycles
Is it possible to change the unit of distance and speed from km to miles on a Kettler Giro GT?
Dear Sir:
Go under the display board, and we the point from some pencil, introduce in the small orifice, reset and you will have the change km vs mls or viceversa.
sincereLY. God bless you
May 03, 2012 | Kettler Exercise & Fitness
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email or
Jul 17, 2010 | Kettler TX1 Treadmill with FREE INSIDE...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Mar 29, 2009 | Kettler Exercise & Fitness
Exercise & Fitness Logo
116 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven Brandon
Steven Brandon
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
