Question about i-mate Pocket PC
The screen won't respond
I'm using a O2 xda Stealth and the screen suddenly won't respond upon tap. Sometimes the keys are working, sometimes they are not. Also, sometimes the phone may hang at the start-up screen.
    An expert whose answer gotĀ voted for 100 times.
  • 146 Answers
Re: the screen won't respond
Format your phone and reinstall the os once again...
this will sort the problem
all the best
Posted on Feb 01, 2008
0 characters
3 Points
My o2 xda stealth phone hanged b coz of virus help me out m not having setup cd wanna format my cell
First of all switched offf this cell u can remove its battery & put it again then wait for a 10second then do this magic
PRESS !<< & >>! & same time Press Power switch {left button in centre jog dial + right button in centre jog dial + Power Switch} & wait for a munit u ill see on screen formating at this time press Green Button thats is call button & this ill hard reset your O2 xda stealth
Mar 18, 2010 | O2 Xda Stealth Smartphone
How will i install my O2 stealth to my pc... i don't hav the disc for installer because it was just given to me by my friend... im running windows Xp.. please help
Free tech support for O2 Xda Stealth Smartphone and help with O2 Xda Stealth ... power device not boot soft reset o2 xda stealth hard reset o2 stealth white ... My O2stealth does not boot! All you see is the O2 welcome. ... dear friend, i just bought O2 stealth, and i want
Oct 29, 2009 | O2 Xda Stealth Smartphone
O2 Xda stealth unlock problem
I just got an O2 Xda stealth from my friends but it has problem with unlocking the key pad.
I can not enter the menu since keypad being lock.
Whati should I do....? how to unlock it
Many Thanks
Oct 05, 2009 | O2 Xda Stealth Smartphone
O2 Xda Stealth: Can't Call and Access Contacts
first, back up all of your data and then reboot it by..
- turn off your phone
- then press these 3 buttons at the same time and hold them for 5 seconds
* power button
* window button
* OK button
Feb 07, 2009 | O2 Xda Stealth Smartphone
My mobile suddenly hang, it's charging but it cant response..
bad news for ya to change u r handset.
Jan 30, 2009 | O2 Xda Stealth Smartphone
I have problem with my screen
hello ...i have the same problem and situation.Unfortunately that damaged the LCD already bec the glass cleaner absorbs the liquid that makes it unresponsive to taps. You got to have that replaced or have that checked by authorized dealers or repair centers.
Apr 11, 2008 | O2 Xda IIs Pocket PC
O2 XDA ii screen does not align
how to align screen xda ii
Mar 12, 2008 | O2 Xda II mini
Screen keeps going blank - then only works when connected to mains adapter or usb
i have the same problem, but sometimes when i connect the charger it does not charge or pcsync..
where the charge slot is on xda-orbit/htc-p3300, there is 2pins inside and if i slightly bend them to ensure a connection it works no problem.
when i disconnect the phone from charge or pcsync, it keeps turning off.
any hints wat to do if hard reset dont work?
Dec 31, 2007 | O2 Xda Orbit Smartphone
O2 Xda stealth shows the welcome screen only .Stuck !
Before you start pull out the memory card maybe very full and causing slow load/lock up, then startup bearing sometime its very slow if unsucessful then pull battery out and try again !
Hope this helps!!
Dec 22, 2007 | O2 Xda Stealth Smartphone
My O2 XDA II LCD touchscreen did not respond frequently
I there, My XDA II has developed exactly the same problem and I think I have descovered what the problem is... My XDA as a very small gap between the screen and the plastic case, I noticed that a piece of grit gad got in there and I used the corner of a piece of paper to try to remove the particle. I was unsuccessful and only managed to move the piece of grit up to the top right hab corner of the screen. Imediatly after this I started having trouble. I have now found if I push the plastic case into closer proximity to the screen I starts to work again. Please try this and see how you get on. It may be that I have to have my screen replaced!! Or at the very least the dust etc cleaned out from around the screen.
Oct 25, 2006 | O2 Xda II Smartphone
i-mate Pocket PC Logo
76 people viewed this question
Top i-mate PDAs Experts
Martin Murray
bharat patel
Are you an i-mate PDA Expert? Answer questions, earn points and help others
