Question about Kenwood Car Audio & Video
The kenwood - 5206 sorry my first post it's a car amplifier and I just recooked it up same no output I unhooked the ground light stayed on I then unplugged the rca's it went off
Duncan
  • 218 Answers
SOURCE: MTX 502 2 chanel amp Pre amp problem?
Unless your amp is 1 (one) ohm stable then you may have fried it. When you attach a 2 ohm load across a bridged amp then you have effectivly placed each output channel on a 1 ohm load. Not a good thing in most cases. Try hooking up ONE speaker on one channel and one input to that one channel one at a time. Then switch the speaker/input to the other channel and see if you can get either or both channels to work independently. Needless to say you must turn the amp off before you make ANY change in the wiring.
Posted on Jun 25, 2007
  • 4 Answers
SOURCE: DUB2502 amp
you probably have the speakers set to where it ecxeeds the ohm load limits. its only 4 ohm stable when bridged and two ohm stable when ran using two channels. so either run the speakers at 8 ohms each parallel or just hook one speaker to eack channel. if you do not know what i am talking about then just email me at grandam88@hotmail.com and give me the speaker specifications.
Posted on Oct 07, 2007
  • 31 Answers
SOURCE: i need help hooking this up
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Posted on Mar 30, 2008
  • 7 Answers
SOURCE: kenwood 9102d wont power on
YOu might have burned out the inner fuse. Better yet the source connect...
Posted on Nov 06, 2008
  • 155 Answers
SOURCE: looking for owners manuel for kenwood car amplifier ps 200
try retrevo.com seems to work for me..
Posted on May 11, 2010
Red and blue light stays on but it cuts on and off, what's the problem? It comes on and works but the red light stays on along with the blue light..when the speaker cuts out, it acts like its trying to...
hi there
The reason for this is the ground is weak to the amp make sure that the post that your ground wire is screwed down to is tight also make sure that is touching bare metal if there is paint on bottom side use wire brush to get the paint off so it is bare metal a weak ground can mess the amp up and make it not work at all hope this helps you have a wonderful day
Aug 23, 2011 | Kenwood KAC-7204 Car Audio Amplifier
Power light keeps on blinking on and off. when ground is disconnected light stops but subs still arent playin
A speaker cable may be short-circuited.
• A speaker output may be in contact with
the ground.
• The temperature of the internal parts may
be higher than 120°C (248°F)
• The fuse of this unit may be blown.
• The unit may be malfunctioning and
sending DC signal to the speaker output.
• The sigma servo connection may be
erroneous.
Oct 11, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Keeps flashing Protect
there is a short in one of the speakers,or the outputs in the amp blew.
unhook the speakers and try it.
if the protect stays on,the amp is blown.
in the winter when the defrost is run on hot,it can overheat the amplifier.
Jan 12, 2010 | Kenwood KDC-MP205 CD Player
On a kac-x650d does the power light stay on or flash
Hello mpredday,
The Kenwood Excelon KAC-X650D power light is ON during normal operation. It blinks blue to indicate BMS selection, yellow for low voltage, purple for DC voltage on the outputs, red for overheating, and green for a shorted or grounded speaker wire.
Hope this helps.
Jul 29, 2009 | Kenwood Car Audio & Video
Kenwood 7204 car amplifier flashes the blue light on top then blows the fuse''
Hello rogman9570,
I'd begin by checking all of the wiring. The most probable causes of this type of failure indication are:
• Speaker wire may be short-circuited.
• Speaker output contacts ground.
• Head unit (cassette receiver, CD receiver, etc.) or the amp ground fails.
If all of your wiring checks out OK, then the amp itself probably has an internal fault.
Hope this helps.
May 18, 2009 | Kenwood KAC-7204 Car Audio Amplifier
Kenwood 9102d wont power on
Nov 06, 2008 | Kenwood KAC-9102D Car Audio Amplifier
My kenwood amp wont turn on
What kind of "Clips" did you put on? They may be causing too much resistance and preventing the amp from getting the current it needs. Double-check with a voltmeter that you are getting at least 12 volts at the amp power connections and make sure your ground lead is as short as possible and connected to solid metal of the vehicle's chassis.
Aug 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My A3201Q
Try unhooking the power, ground, and remote wires for a couple of minutes, also check all fuses on amplifier and fuse for power cable (usually under hood around battery), and don't forget to check ground wire connection for "good" contact.
Mar 15, 2008 | Car Audio & Video
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Fan stays on, light turns off
try using a better ground. while new cars are great, they also have more paint and plastic in the works...so finding a good ground for your amp to run off of isnt always easy. you can try running a gbround cable straight to the negative terminal of your battery to test the amp, poor grounding is the most comon cause of amp failure. ps,the fan may be staying on as a protective service, as if your amp loses ground whenpowered up it will keep the cicuit boardfrom heating up on voltage surges.
Jan 06, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
41 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
