My model v3440 (white),tray full light stays on, the instructions says "using thumb and index fingers of both hands, push tabs inward and pull up". I do not see tabs for this model,
My model v3440 white color does not have tabs to remove bottom tray light stays on
yeroc
  • 397 Answers
SOURCE: Ceiling fan light works with wall switch, but comes on dim when I pull the chain for the fan
is the fan working correctly, if it is not it could be a bad armature or field
Posted on Jan 20, 2008
georgete
  • 13 Answers
SOURCE: Removal of tray on Safety 1st high chair
go and chek the mainual of the chair
Posted on Mar 24, 2009
welcomejee
  • 10594 Answers
SOURCE: Overlaping colors
NO, does not lamp problem.
If its rear projection TV then its convergence our ICs failure problem and need to be replaced these ICs.
Let me know exact model and brand of TV for more info.
Posted on Apr 30, 2009
  • 68 Answers
SOURCE: Even though my printer settings
Two things to check for a problem like this:
1) Driver Settings:
If your computer's drivers are telling the machine to pull from the bypass tray it'll ignore the machine settings. You're kind of on your own here figuring it out, if you can't though then try deleting the printer from the computer and re-installing it (will default settings)
2) Manual Feed sensor:
When you put paper into the bypass try you're activating a flag which tells a sensor there's paper there, if this flag is stuck forcing the sensor to constantly think you have paper there it would always to pull from there. Find the flag, move it back and forth, hit it with some air from a can of air.
Posted on May 31, 2011
  • 3 Answers
SOURCE: I have a Foodsaver 3420
Place a small piece of electrical tape over the contacts on the fluid tray. This will allow the machine to operate but you'll have to manually check the tray for liquids/cleaning.
Posted on Jul 31, 2011
Fuse panel diagram 2002
On the passenger side footwell. On the left, one philips screw to remove carpet panel. Black plastic piece needs to be removed, some have plastic nut to turn to remove. Some just pull towards the back of the caricon1.png and down at the same time. Tucked in there is the blower resistor "blower switch" with a 4 or 5 wire connector on it. With right hand push on tabs and remove connector. Then with right thumb and index finger grab the blower resistors connector and with your middle finger push down on the plastic tab and pull out. When installing new one make sure to line up the guide pin.
Mar 18, 2014 | 2002 BMW 330
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
I have a baby stroller similar like this (Peg Perego). I bought it from a yard sale. I just want to know how to "fold down" this baby stroller. I hope it is similar to this model. ...
There are little finger/thumb grips right below the handles that you push with. Not the long oval thing, that adjusts the handle height, but little grips on front and back of the handle. On both left and right handles. you put your index finger under front one and middle finger under back one, (both sides at same time, use both hands) and pull UP on them while leaning the stroller forward to fold it down, push it down until it clicks.
Note: Don't pull the release clips manually.
Good Luck!
Jan 04, 2011 | Peg Perego Aria MT - Blue Moon Stroller
Tail light is burned out on tail light. I have the bulbs but can't figure out how to remove and replace burned out light.
  1. Check with your local auto parts store or look in your owner's manual to find the proper model number of the replacement tail light globe.
  2. Open your trunk or lift your hatchback. Find the cover just on the inside of your vehicle next to the burnt-out bulb.
  3. Turn the two latches counterclockwise to open them so the cover may be removed. In most cases you can turn the latches with your fingers; in some cases you may need a coin or a slot screwdriver to turn them. Remove the cover.
  4. Press the tabs that allow you to remove the tray that holds the tail light globes. There are four tabs on most VW models. Each tab must be depressed to release the tray. Pull the tray out a few inches, as far as the wiring allows.
  5. Press down slightly on the burned-out globe and turn it counterclockwise with your thumb and fingers. It should release easily and then pull straight out. Push the replacement bulb in and turn it clockwise until it locks in place.
  6. Snap the tail light tray back in place. The tray should simply push back into place and the four tabs should "snap" into their locked position. Replace the door cover and turn the door locks clockwise. Test your bulb to see that it is working.
Good Luck
Nov 20, 2010 | 2004 Volkswagen Beetle
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
THE A/C BLOWER DOES NOT WORK IN MY 2002 BMW. THE FUSES HAVE BEEN CHECKED AND ARE OK. WE HAVE OREDERED A BLOWER SWITCH. WE NEED A DIAGRAM ON WHERE TO INSTALL THIS IN MY BMW.
On the passenger side footwell. On the left, one philips screw to remove carpet panel. Black plastic piece needs to be removed, some have plastic nut to turn to remove. Some just pull towards the back of the car and down at the same time. Tucked in there is the blower resistor "blower switch" with a 4 or 5 wire connector on it. With right hand push on tabs and remove connector. Then with right thumb and index finger grab the blower resistors connector and with your middle finger push down on the plastic tab and pull out. When installing new one make sure to line up the guide pin.
Jun 19, 2009 | 2001 BMW 325
Battery
Several suggestions:
Put 7130 on table face down.
Grab sides of BB with thumb and middle finger of one hand at the bottom of the cover where it has the larger part.
with other hand, use index finder to push down the locking button while shifting with the first hand.
Or:
attach a four inch lenth of scotch tape on the battery cover with the loose end hanging off the bottom to use as a pull tab.
Then use a finger nail to depress the release button just a slight amount. It's important to press down on the top edge of the button. Also it is very important not to press to hard because the amount of downward movement to release it is very small. If you press it down too far it binds and prevents the latch from releasing.
The key is to use the pull tab you made from tape to slide the cover off once you have released the latch.
or:
1. Take a letter opener or a flat head screw driver and push down on the top portion of the tab. The tab is located on the back side of the phone at the bottom.
2. Don't push down to hard
3. While pushing down use your free hands thumb to push down and slide the cover off the bottom of the phone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | RIM Blackberry 7130e Smartphone
I have tried to change the battery in Thomas but this seems impossible! I think it is 2002 model. I bought it for my grandson at a car boot sale today and it is in lovely condition but the battery is
Take the wheel base of the train in one hand. Point the' face straight up. Place your other hand on the top with you index finger on Thomas' face. Push down towards the ground with the hand on the top, and then pull apart. There is a little tab on the back that you need to get over. Some times the first time is the hardest.
May 10, 2009 | Learning Curve Toys Thomas the Tank Engine...
Instruction for a pegpergo stroller to close
There are little finger/thumb grips right below the handles that you push with. Not the long oval thing, that adjusts the handle height, but little grips on front and back of the handle. On both left and right handles. you put your index finger under front one and middle finger under back one, (both sides at same time, use both hands) and pull UP on them while leaning the stroller forward to fold it down, push it down until it clicks. Open same way, pull up on same grips to release the click lock.
good luck, DON'T PULL RELEASE CLIPS UP MANUALLY, THEY WILL SNAP AND YOUR STROLLER WILL NO LONGER CLOSE, MY DAD BROKE BOTH OF MINE.
May 01, 2009 | Peg Perego Baby Gear
I've forgotten how to replace an ink cartridge in my HPpsc2110
This works for a HP Deskjet F380 All-in-One. I don't know if the first step is necessary, but do it anyway.
o Unplug your printer.
o Remove paper from the paper tray and leave it opened.
o Pull down the white door above the tray to open it. The inside of this door has instructions for replacing the cartridges. My problem was to find the spent cartridges.
o The cartridges are inside the space opened up by the last two steps. Put your hand in until you touch the horizontal rod that transverses this space. Feel to the left and slightly down until you find them, then slide them along the rod until you can get at them.
o To remove one, clasp it with your thumb on top and your bent index finger beneath. Pull back and down, bearing down with your thumb and using your finger as an axis, and it should pop right out.
o Take the tape off the replacement cartridge. Don't touch the coppery area under the tape! Roll the new cartridge in with a motion opposite from the one you used to remove the old one.
Good luck. images are so much better than words for this kind of thing. --Akren
May 01, 2008 | Office Equipment & Supplies
19 people viewed this question
k24674
jasbo
jasbo
