Question about Toro Garden
What is the spark plug gap on a Toro 98 powerlite cc
    Top Expert:
  • 4,740 Answers
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
Posted on Feb 26, 2011
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
What is spark plug gap settings for a toro tb22ec trimmer
You don't have to gap the plugs on 2 cycle and 4 cycle equipment. They are already pregapped. Look at the part number of the plug and go get yourself an E3 brand plug which covers multiple plug numbers...best plugs on the market.
Sep 28, 2015 | Toro Garden
What's the proper gap for a toro mower spark plug
Spark plug gaps for lawnmowers and lawn tractors are not as critical as they are for motor vehicles. Generally, an acceptable spark gap is anywhere between .025" and .035".
May 13, 2015 | Toro Garden
What is the air gap on the toro 20005 serial 250067677
you mean coil air gap ??? spark plug gap ??? should of included the engine numbers because that's not made by Toro !!!
.011 is the coil gap
.028 is the spark plug gap
Oct 12, 2014 | Garden
I have a toro 98 cc powerlite snow blower. did not drain fuel after storing for the summer. drained fuel, put new mixed fuel in and engine wouldn't start. replaced spark plug, cleaned carb and bottom
cleaning the carb was a good thing if done properly. fuel tarnishes over time and this tarnish destroys diaphragms in carbs and also plugs up the jets. If you used compressed air at a high velocity then you may have damaged the internal check valves in the carb. Also check your fuel filter and air filter
Oct 08, 2014 | Garden
Toro powerlite 98 cc 16" Mod no 38182 ser
heatman101
Feb 26, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
What is the ratio of gas to oil for a toro powerlite 98 cc Engine model # 38172
The manual can be downloaded from this webpage, you need the serial number to do this.
https://lookup3.toro.com/request/request.cfm?lang=uk_en
Two stroke engines usually use a 1:50 oil/gas mixture but it would be wise to consult the manual.
Hope this helps !
Feb 20, 2011 | Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
