Question about Kenmore 299825C Humidifier Filter Sears Wick
Sears model no. 758.743303 humidifier shaft stops that turns belt knocks and stops turning the roto-belt
How do I fix my blower problem on my humidifier?
Free Sears Humidifier User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > ... > Household Appliance Sears
Products 1 - 11 of 11 - Sears Humidifier 758.144120. Sears Kenmore Evaporative Console Humidifier Owner's Manual. Pages: 0 Saves: 0. See Prices
Oct 29, 2015 | Kenmore Quiet Comfort 12 Humidifier Filter...
Plugged in my Aprilaire 700 humidifier after having it off all summer and it does not turn on
Make sure it is plugged into a live circuit, and there is a knock over switch inside somewhere so if it gets knocked over it won't start a fire.
Oct 20, 2014 | Humidifiers
I can't find a replacement filter for Sears Kenmore humidifier model 758743303
Find someone with internet capabilities, and type in the words "Sears Parts" into your search engine. "Sears parts" has pictures and parts for most appliances. Be really sure you have your complete model number. They should show you a picture of your humidifier, and give you a part number. They can ship you the part, or you can go to "e-bay" and try to buy it.
Be blessed.
Jan 30, 2014 | Kenmore Humidifiers
My furnace is about 5 years old and the humidifier(skuttle190) has not been used in several years. I just ordered a new filter as the present one that I have does not fit properly on the wheel, its too...
Hello, if this is a drum type humidifier the small motor that turns the drum might be bad, take the drum off and see if the small shaft of the motor turn without the drum on it. if it does not turn than most likey the shaft or the internal parts of the motor are craked and must be replaced. If it does turn without the drum on it than either the filter is causing the problem or the drum is not seated properly. I hope this helps
Feb 13, 2011 | Skuttle 190 Humidifier
Model 760 Aprilaire makes a loud noise when running. It almost sounds like the blade is hitting something. Its 10 years old !! I built the house so if you can tell me for sure what it is I'm sure I can fix...
I think you're on the rate track. If it's ten years old the blade and.or the shaft may be worn out. Turn off the water line feeding the humidifier.Turn off the electricity to the unit. Drain the tank, open he tank cover and try spinning the blades with your hand. That way you can tell and see what its rubbing against and if it can be repaired. But, if it's 10 years old, parts may not still be available for that specific model.
Good luck. Hope that helps.
Feb 11, 2011 | Aprilaire 700 Humidifier
Humidifier only blows on "low" when turned on.
need to replace fan control switch. CK SEARS FOR REPLACEMENT PARTS.you will have to order
Jan 06, 2011 | Kenmore 14417 Humidifier
MOTOR IS NOISE
Sounds like your motor bearings are going bad. If at all possible lubricate the motor bearings using a few drops of a NON detergent oil. If the motor has sealed bearings with no oil ports then you should replace the blower motor.
Good luck
Mar 29, 2009 | Essick Air 447 302 Console Whole House...
Knocking nosie when water enters humidfier
That would the the 24volt soleniod valve that the water line attaches to. Steve
Dec 20, 2008 | General Filters 1042-LH Humidifier
Water Wheel won't keep turning
This humifier has a black drive wheel and a white idler wheel. On mine, the idler wheel froze up which caused the drive wheel to damage itself trying to turn the drum. First, free up the idler wheel and replace the shaft it rotates on. The idler wheel is still available but you'll have to fabricate the shaft using a machine screw and hollow shaft from your local hardware store. When the idler wheel turns freely, the drive wheel (if still in decent shape) can do its job of turning the drum. If not, you can replace the drive wheel (also still available). I recently put a small rubber band in the groove of the drive wheel and it enabled it to get the necessary grip on the drum.
It's getting harder and harder to keep these wonderful Bemis water Wheel humidifiers alive as the years go by. I wish they still made them because no other humidifier comes close.
Rick
Dec 18, 2008 | Bemis 4D7-800 Humidifier
Kenmore 299825C Humidifier Filter Sears Wick Logo
60 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
ftykjg
ftykjg
julian hayes
julian hayes
Level 1 Expert
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
