Question about Toro Garden
What is the spark plug gap on a Toro powerlite 98cc engine
    Top Expert:
  • Toro Master
  • 8,150 Answers
rycgl
  • 1545 Answers
SOURCE: spark plug gap fpr a
Typical old Briggs flathead "L-Head" engines require about a .030" plug gap.
Posted on Jun 13, 2010
  • 407 Answers
SOURCE: what is the oil capacity for a toro 6.75 hand
20 oz of oil
gap at 0.035
Posted on May 10, 2011
2strokeJim
  • 577 Answers
SOURCE: what is the spark plug gap for a Toro 450, GTS2
most generally out of the box your good to go! not like the old days !
Posted on May 17, 2011
BAMOUT
  • 2478 Answers
SOURCE: toro 6.5hp gts tecumseh engine.what is the spark plug setting
MOst all is .030". Go to www.managemylife.com and get your free manual.
Posted on May 18, 2012
  • 201 Answers
SOURCE: Toro walk behind lawn mower. Model 20074. New spark plug, gapped to.030", verified that there is a spark, cleaned carburator and jets. won't start even with starting fluid. Any suggestions?
advise doing a compression test with gauge.
could be valve not seating or low compression
Posted on May 27, 2014
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
What is spark plug gap settings for a toro tb22ec trimmer
You don't have to gap the plugs on 2 cycle and 4 cycle equipment. They are already pregapped. Look at the part number of the plug and go get yourself an E3 brand plug which covers multiple plug numbers...best plugs on the market.
Sep 28, 2015 | Toro Garden
What's the proper gap for a toro mower spark plug
Spark plug gaps for lawnmowers and lawn tractors are not as critical as they are for motor vehicles. Generally, an acceptable spark gap is anywhere between .025" and .035".
May 13, 2015 | Toro Garden
What is the air gap on the toro 20005 serial 250067677
you mean coil air gap ??? spark plug gap ??? should of included the engine numbers because that's not made by Toro !!!
.011 is the coil gap
.028 is the spark plug gap
Oct 12, 2014 | Garden
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
Toro powerlite 98cc engine...unit will start by pull motion but will not continue to run beyond 2 minutes or so....electric start no longer executes...get clicking sound
I believe your carburetor needs to be rebuilt or replaced. The carb has thin rubber diaphragms that meter in the fuel to combustion chamber. If the diaphragms get hard (from gas sitting in carburetor for extended time or from hot weather) they won't allow enough fuel in to keep up with the demand. if you need parts email desertairrepair@aol.com.
Feb 02, 2010 | Toro Blowers Rake and Vac - Electric...
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
95 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
