Question about Pool & Spa
My Mastertemp 400 will not heat past 89 degrees. what are some of the problems causing this?
  • 21 Answers
Your thermal regulator most likely needs to be checked and replaced. Also check your inside temperature
Posted on Dec 20, 2016
My Pentair Mastertemp 400 temperature is reading 20 degrees too low. I've replaced the thermistor already. Any ideas?
bummer hi limit wont do that but tep sensor will or control board also make sure water is flowing freely,
you will want to check the manifold bypass and thermal regulator
May 29, 2014 | Pentair Mastertemp Heater
My Pentair Mastertemp 400 temperature is reading 15 degrees too low. I've replaced the thermistor already. Any ideas?
Your problem sounds like a faulty control board. I replaced the high limit switch, the thermistor, and the control board in an attempt to resolve an erratic temperature reading (plus and minus 1 degree).
It caused the heater to turn off and on constantly when the target temp was reached. My successful solution involved replacement of the two brown wires that connect the control board to the thermistor. The wires were ok but the connector(s) were not. The thermistor output is very small and the contact must be solid in order for the control board and thermistor to communicate. As for the price of the board...it is closer to $300. The one I purchased (and didn't need) was about $275. Seems like you have done everything except change out the board. It doesn't sound like your problem involves corroded wires. Good luck
Master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
I have the same exact problem with this unit. Obviously getting gas to the unit, because it runs and pumps out some serious heat for a short time, but then kicks off. Did anyone ever figure this out or did you buy a new heater? :-)
Feb 25, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
I have a Pentair Mastertemp 400. It worked fine for 3 years until the temp sensor went out and both (internal and external) were replaced about a year ago. It then worked fine for about another 7-8...
You might have a much bigger issue than the temp sensor. When the heater is running hold the "pool" or the "spa" button for 12 seconds. This will show the exhaust temp, if the temp is rising above 375 degrees with in 1-2 mins then your not getting the heat out of the heat exchanger.
One other thing to check would be an external by-pass. If you have an external by-pass make sure the by-pass is set correctly. Opened or closed to much can cause the problem your having.
Mar 04, 2017 | Pentair MasterTemp 400000 BTU Pool and Spa...
Pool & Spa Logo
289 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
