Number of SATA ports on K837J - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 8,150 Answers
See if this link helps you out.... Identifying the SATA Ports on Your Desktop Board
Posted on Dec 11, 2016
Sata cable & pata cable have a any jumper setting
The hard drive / optical drive have jumper settings, not the motherboard. PATA has jumper settings, but SATA do not require any. The diagram of the setting is drawn on the hard disk itself below the serial number etc. For SATA, look on the motherboard for the SATA ports. Each port will be named as like SATA 0, SATA 1 etc. If you want the hardd disk to boot first, plug it in SATA 0. and the next device in SATA 1. However, you can also set the first and other boot device from the BIOS itself, in case of SATA.
Dec 25, 2013 | Intel Motherboard
My sata has been removed fram my motherboard, only the yellow colour plastic, but the seven pins are their in a motherboard so give me the solution, please fast
Hi shaqi0078666
Meaning now,
pin SATA on SATA port for SATA ports left and you were broken.
what about the other SATA port?
if there is, use the other SATA port for your SATA and SATA cut the pin is left, do not let it come into contact with another pin.
If you do not have SATA ports. you must try to improve by changing the SATA port on the sata port. or you can use sata to ide converter to install a SATA hard disk to your motherboard..
thanks&regards
Dec 15, 2010 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
My ECS motherboard cannot detect the SATA port for my samsung dvd rom. I want to know the solution of this problem.
Go into your BIOS and make sure that your SATA port is turned on. Some BIOSes make you turn them on to detect something plugged into them. Look at the SATA port that you are connecting to on the motherboard. There should be a number next to it, make sure that's the one you turn on in your BIOS.
Mar 24, 2010 | Computers & Internet
Raid settings, i one to set sata drive as primary and ide as secondery
First connect the SATA to port 0 Sata does not have any Primary or secondary port, It has ports SATA0,SATA1,SATA 2, 3 and 4(depending upon the number of ports available on your motherboard), Connect the SATA to port SATA0
Then connect another Drive to IDE 2(secondary). Normally the IDE port closer to the RAM is primary.
To confirm the connection is correct you can look in the BIOS
Please let me know if this information is helpful to you. If you find it helpful please do not forget to rate it.
Thank you for choosing Fixya
Oct 08, 2009 | Intel Motherboard
Sata hard drive could not be detected during win xp installation in acer aspire M3600
It could only be a limited number of problems:
1. SATA drive is not connected to the primary port
2. SATA cable is faulty
3. SATA drive is faulty
The most common solution is to move the cable to the primary/first port
Jul 30, 2009 | Acer Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
Jumper settings for the Masscool XWT-PCIE10
Do you remember the default jumper settings? they're set to external ports' usage.
Have a good day.
Mar 17, 2009 | Fanner Masscool XWT-PCIE10 4-Port SATA PCI...
Sata controller was corrupted. cannot install any sata drives or sata drives was not found on the system.
henx, How do you know that the SATA controller is corrupt?
I see you state that your SATA drives are not beeing found by the system. The SATA controller is defective if your bios does not see a connected SATA drive connected to the SATA port & the SATA power connector is also correct & connected. There is not a fix for your issue. I checked every bios version for your P4S800D-X. No SATA fix through Asus. There is only one way to get your board fixed. You must call Asus tech at 812-282-2787 M-F Eastern time. Please have handy the set of numbers found on a white sticker on the serial port. Asus will need this number. Keep your system together as the tech will want you to do some checks before he will issue you a case number. Keep in mind Asus warrants boards for three years. Asus also can not repair your board's defective SATA controller. They will test it & replace board with another. After receiving a case number you'll have to call CA for a RMA No#. RMA dept, will send you a RMA to your email address along with instructions on how to send the board back to Asus.
Feb 29, 2008 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
