Question about Cell Phones
Smspeepers messages - Cell Phones
Sms messages are changing to mms
In some devices the message type gets converted from SMS text message to MMS multimedia message if the message length exceeds the device-specific setting which is typically 5 - 10 SMS submessages (around 760-1520 characters). If the message is longer, it is converted to MMS to avoid potential issues in handling long text messages in the recipient device. The cost of a SMS message consisting of several concatenated submessages may also be higher than the cost of a single MMS message.
The conversion from SMS text message to MMS multimedia message occurs when the automatic message type is selected in the message options. This is the default mode where the device tries to automatically select the best mode for the message.
The conversion from SMS to MMS can be avoided by selecting Options > Sending options > Message type > Text when in the Text message window writing the message. The message is then always sent as SMS text message and no conversion to MMS occurs.
The maximum number of concatenated SMS submessages can be up to 10 (around 1520 characters). In multimedia mode the message length can be longer.
Nov 12, 2013 | Motorola Mobility QA30 Hint Silicone Case...
I have a new Motorola Cliq2 How do I delete text messages form this phone?
To delete a message or a message thread
  1. From the programs menu, tap Text Messaging
  2. On the Text Messaging screen, tap the message thread that you want to delete.
  3. Do one of the following:
    • To delete the entire thread, press the Menu key and then tap Delete conversation. When prompted to confirm, tap OK.
    • To delete a message in a thread, press and hold the message that you want to delete, and then tap Delete message on the options menu. When prompted to confirm, tap OK.
Note: To delete all messages on the text messaging screen, press the menu key while on the text messaging screen, tap Delete all conversations, tap Yes to confirm.
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/61024/~/cliq-2---delete-and-forward-sms/mms-text-messages
Mar 02, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
How do I set up the voicemail feature?
Messaging - Advisory
To turn Messaging - Advisory on:
1. Press SUPERKEY.
2. Press the No softkey until "Advisory Msgs?" appears.
3. Press the Yes softkey.
4. Press the Next softkey until the desired message appears.
5. Press the TurnOn softkey.
To turn Messaging - Advisory off:
1. Press SUPERKEY.
4. Press the TurnOff softkey.
Messaging - Callback
To leave a Callback Message on a telephone when you hear busy or
ringback tone:
! Press MESSAGE.
To respond to a Message Waiting condition on your telephone:
1. Lift the handset.
2. Press MESSAGE.
A call is placed to the message sender (voice mail system or extension user)
that left the oldest message.
To view information about the messages before responding:
1. Press MESSAGE.
2. Do one of the following.
" To call the message sender, press the Call softkey (if available).
" To delete the message, press the Erase Msg softkey.
" To view the next message, press MESSAGE.
Jun 10, 2010 | Mitel Superset 4025 Corded Phone...
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
How do i reset the settings so that the default message is SMS
Changing your text message
settings
Your KC550 message settings are predefined so that you can send messages immediately. If you would like to change the settings, you
can do this using the Settings options.
Press Menu, select Messaging, then choose
Settings and Text message. You can make
changes to:
Message types - Convert your text into
Voice, Fax, Paging, X.400, Email or ERMES.
Validity period - Choose how long your
message is stored at the message centre.
Delivery report - Choose to receive confi rmation that your message was
delivered. Reply charging - Choose to be billed for your message recipient’s reply. Message centre number - Enter the details
for your message centre. Character encoding - Choose how your
characters are encoded. This impacts the size of your message and therefore data charges. Send long text as - Choose whether to
send your message as SMS or MMS when you enter a text longer than 2 pages in the message field.
Bearer setting - Choose whether to send your messages via GSM or GPRS. Changing your multimedia message
settings Your KC550 message settings are predefi
can do so using the Settings options. Press Menu, select Messaging, then choose Settings and Multimedia message.
You can make changes to:
Slide duration - Choose how long your
slides appear on screen. Priority - Choose the priority level of your
multimedia message. Validity period - Choose how long your
message is stored at the message centre. Delivery report - Choose to allow and/or request a delivery report.
FOR MORE SEE USER MANUAL
good luck
Mar 21, 2010 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Message Box is full. How do I erase?
Erase Messages
Single Messages
You can erase a message itself, leaving the Caller ID information.
• While the message is playing, press and release DELETE. The unit erases the current message and announces, "Message erased."
All Messages
You can also erase all the old messages only, leaving the new messages and Caller ID information.
While the unit is in ready-to-answer mode, press and hold DELETE until the unit announces, "Messages erased."
• New messages can not be erased in this way. To erase new messages, play them then press DELETE during play back.
Here is a link for the manual for your phone:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
Apr 26, 2009 | GE 29897GE1 Corded Phone
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
Oct 22, 2008 | Motorola Mobility RAZR V3
How to read dvr messages
From the R10 user's manual:
From time to time DIRECTV may send you messages about updates to your service and other important notices. These messages are important, useful, and easy to find. When your DIRECTV® DVR receives a new message, a message icon ( ) appears on the channel banner and in DIRECTV Central.
To read a message:
1. From DIRECTV Central, select Messages & Setup.
2. Select Messages.
3. Select the message you want to read.
Use the CHAN DOWN button to see text that does not fit on the screen. When you are finished reading a message, select Done or Delete Message. Selecting the message icon in the channel banner will take you to your list of messages. The message list will display “No Messages” if there are no messages to read.
You can download the full user manual for your R10 here.
Oct 19, 2007 | Directv R10 TV Receivers and DVRs
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
