Question about Bosch Refrigerators
The letters al and a red light are showing on my Bosch upright freezer, the roof of the top compartment is icey. freezer is in garage, but I have small heater which I have on when very cold
  • Bosch Master
  • 610 Answers
Will it keep ice cream at firm and edible consistency? Help Me Find My Model Number
Posted on Dec 12, 2016
I have a Crosley refrigerator that is about a year old. We decided to replace it because it wasn't big enough. We moved it to our garage and since we've moved it, it doesn't seem to be chilling the...
If the garage is unheated and the garage temperature is below 50 deg F this is the reason that the freezer is not able to freeze. A refrigerator is designed to work in a heated space. The thermostat is in the refrigerator compartment while the cold evap coils are in the freezer compartment. The fridge thermostat is typically set to around 40 deg F. When the fridge is in a colder environment, the compressor does not need to work that hard to get the refrigerator to temperature. But the freezer on the other hand, will be above freezing.
To fix this, there are garage refrigerator heater kits available, for just this situation. They are placed in the refridgerator compartment to heat the thermostat. This causes the compressor to run longer, and thus maintain the freezer temperature better. You could get one of these heaters or you could put an light bulb in the refrigerator to do the same thing as the heater. Remember to use a regular light bulb, and not a cfl or led light bulb, they won't generate enough heat. Also remove the light bulb or heater in the warm months unless you want a higher energy bill. Hope this helps you.
Dec 09, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Amana arb1917cc fridge not cooling no sounds from it at all light is on how do i fix this problem ?
Good day,
If the lights work, and nothing at all is running, then it is either the defrost timer stuck in defrost, or the main thermostat in the freezer compartment has failed.
Check the timer first. With the freezer control in the freezer compartment set to at least 4 or higher, look for a small hole in the fresh food compartment. It is in the roof (top) of the compartment almost half way back.
With a small screw driver, turn the shaft of the timer clockwise at least a 1/4 of a turn. If it starts, then the timer is bad and needs replaced.
If no luck then it would be the thermostat in the freezer compartment that failed.
P.S. As with all machines, a broken wire could be the problem but on your model, is extremely rare.
Dec 13, 2009 | Amana ARB1917CSR Bottom Freezer...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Bosch classixx refridgerator
the evaporator is probably iced up and hence poor air flow. (i am assuming it is a frost-free type). switch off and leave for 24 hours with door open is the easy cure. otherwise, remove the back inside panel of the freezer and melt off the excess ice with a hairdryer used carefully
Jun 02, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Open Questions:
Bosch Fridge Freezer Model kan60a45g - Water Dispenser is not working, only a tiny dribble!! I've proven water flow to the egress / exit of the water tank... I have a Bosch American Style Fridge Freezer Model kan60a45g. The water flow out of the built in dispenser has gone from perfectly fine to a tiny dribble, it was gradual and I assumed it was the filter needing to be replaced. However replacing the filter seemed to make it worse, so I replaced filter with the plug in order to remove it from the equation. It still didn't work, so I went to the beginning of the flow and confirmed the pressure / flow into the "in pipe" was fine. I then checked flow to and from the filter unit, again fine. Down now to the inlet valve (I think it is called) and I checked all the valves worked here when required - they do. Next I checked the flow at the point of entering the water tank which sits in the fridge. It seems fine. I removed and flushed the tank and confirmed there are no problems with its flow when refitted. So sadly it seems the problem is somewhere between the exit of the water tank and the outlet in the freezer door itself. Everything else is checked out. I cannot see how the pipework runs from the fridge side into the freezer section and then up through the hinge of the freezer door. Does anyone have any suggestions? Ideally I suppose I would remove and replace the pipe - it has to be blocked somewhere I guess? Could I blast with compressed air? If anyone has experience of this issue, or knowledge of how to remove this last bit of pipe work then I would be very grateful. Thanks in advance!
Mar 01, 2018 | Bosch Refrigerators
Refrigerators Logo
49 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
