How to mount a TV on Tonin Casa Cortes TV stand?
I do not know how to install my TV on my Cortes TV stand. Are there instructions that an be found somewhere / does anyone know how to mount the TV?
  • 5 Answers
SOURCE: PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
Posted on Jun 10, 2008
bernardlunda
  • 318 Answers
SOURCE: Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Posted on Mar 26, 2009
  • 10865 Answers
SOURCE: Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
Posted on May 23, 2009
ldaala
  • 65 Answers
SOURCE: need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
Posted on May 26, 2009
BusRider
  • 15 Answers
SOURCE: I need an Insignia TV stand for a 42" LCD HDTV
Try the T.V. manufactures website, E-Bay or the store where you got the T.V. from.
Posted on Jul 26, 2009
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
CANN NOT SEEM TO MOUNT THE TV ON THE STAND PROPERLY
Mounting instructions are in with the setup instruction for the TV or TV Stand. Did a mount come with the stand, or is it a separate add on to the stand? In some cases TV Mounts do come as an option?
Feb 26, 2014 | Whalen Furniture Austen 3-in-1 TV Stand...
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Hi I have been given a plasma tv Relisys
http://www.mountright.com/desk-mount-desk-bracket-for-1422-lcd-tv-swivel-1406-21r-p-27.html
I found this site and it has a desk mount bracket for your tv.
Relisys has gone into administration so getting the origional stand could be difficult.
I hope this helps
May 08, 2010 | Televison & Video
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
