What device do i select for wha ta movie onhbo
HOW DO I USE THE USB PORT TO PLAY MOVIES
Tom,
To be able to play movies stored on a USB device (it doesn´t matter if it's a usb pen, a usb hard drive, etc), you will need two things:
1.- The device where you want to play the movies must support the USB device that you're using (not all USBs are the same, and they can be formatted differently, too). So if when you plug it in, the TV doesn´t recognize it, use a different USB device.
2.- The movies that you put on the USB device must be palyable by your device. ie: your TV, BluRay, etc must be able to decode and play the movie format, and this can be AVI, DIVX, XVID, H624, QT, MKV, etc. Even if your device reproduces DIVX movies, if the movie is encoded in a weird format, it won't be playable. The fastest way to know is trial and error.
Feb 09, 2015 | Hard Computers & Internet
Usb device not working on tv
go to menu when you get to categories use your chanels buttons to move and select
Dec 07, 2013 | Cell Phones
Need 6 digit access code for epixhd for ps3
1) Select the movie you want to watch by highlighting the movie image and pressing "A" (Play). The first time you do this, you will be prompted for a 6-digit code.
2) Go here (http://www.epixhd.com/watchnow/) to get that code. Select your provider and Sign In with your credentials, or if you don't subscribe to EPIX yet, select the 14 Day Free Trial (or go here to sign up for your Free Trial: http://www.epixhd.com/freetrial-devices/).
3) Once you've successfully signed in, you will see the Devices tab on your Me page. Select Xbox 360 and your 6-digit code will appear.
4) Enter your new 6-digit code on your Xbox 360 and start watching movies. Please note: you must use your device code within one hour or you will need to get a new one.
Oct 21, 2013 | Sony Playstation 3 (PS3) Console
Using usb stick
First you will have either copy and pate the movie or download it to your usb drive
One of the benefits of putting files on a USB flash drive is that you can make any type of file portable.
This includes not only documents, spreadsheets and photos, but also media like video clips and movies.
If you have movies saved on your flash drive that you want to view, watching the movies directly from the USB drive is a simple process and can be achieved on almost any computer.
Connect your USB drive to the device on which you want to watch your movies.
This includes all USB-compatible computers, as well as some select television-compatible devices (like the PlayStation 3, Xbox 360 or Sony Media Extender).
Launch the file explorer application on your device.
In Windows, access this utility by accessing the "Computer" application and then double-clicking the USB drive to display the files.
If you are trying to watch the movie files on a compatible television device, look for a "media," "device" or "USB input" application or button to bring up the file explorer.
Select the movie file you want to play.
In Windows, do this by double-clicking on the file.
The appropriate media-handling program should automatically launch and begin playing the movie automatically.
If you are using a television device, select the file from the list of compatible files in the device's internal explorer system.
hope this helps
Oct 15, 2012 | Computers & Internet
Hi how do i connect my external hard drive to my ps3 and watch films
Step 1. Connect your storage device (I usually use a pen drive) to your computer
Step 2. Copy Movie to the storage device
Step 3. Eject storage device and connect to your ps3 via the USB port.
Step 4. under videos an option of your storage device should be there but do not choose X button instead press triangle for options, then select display all.
Step 6. Locate your movie and select it using X button.
Step 7. Enjoy the movie!!!! This works with MOST movie files, you may find problems watching some movie because of the way they were encoded.
Step 8. Done.
Good Luck
Jun 28, 2011 | Sony Playstation 3 (PS3) Console
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
Hello im i install my web cam bt i notice i only could of do a video n i cant hear any audio during the video plus i cant take any pictures canu please tell wat do i hav ta do ta fix all of that
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 14, 2010 | IC Intracom Manhattan FUN! CAM Webcam
I,subhajit chakraborty got a msg from ta-hrinfo that myresume got selected by Bajaj limited but i unable to open the link given by you.The link is:2shared.com/photo/aKGQosRJ/BJAJA_-_A.html
same i to got a msg from ta-hrinfo that myresume got selected by Bajaj limited but i unable to open the link given by you.The link is:2shared.com/photo/aKGQosRJ/BJAJA_-_A.html
Sep 10, 2010 | Computers & Internet
Sound device
Open my Computer And right click Click Properties Open the hardware tab Click device manager
Select the sound card and select install drivers
Select "allow windows to connect to the internet to search for the drivers to this device"
Click next, and windows will - hopefully - find and install the drivers for you.
It might be worth posting the model of your sound card so i can see if i can find the drivers for you
Ta
Ben
Sep 07, 2008 | Computers & Internet
29 people viewed this question
 Grubhead
Grubhead
