STUCK IN USB MODE WITH NO REMOTE - Televison & Video
How do i change my aveis tv from usb mode to tv mode without a remote?
I would suggest you take that remote back. I got a cheap 8 dollar GE remote from Dollar General for 8 bucks and all that is required to program it is for the TV to be on. I've never heard of a universal remote having to be in TV mode as that would defeat the purpose.
Feb 14, 2015 | Televison & Video
Screen locked on safe mode
you may have a "stuck button" this usually triggers safe mode.
check for stuck buttons if you dont have any
do the following
1.Remove the batteries
2.Press and Hold the #2 Button
3. Plug into the USB port of a computer dont release #2
4. That should unlock safe mode
Mar 05, 2011 | Logitech Harmony 550 Remote Control
What is "Safe Mode?and how do I get this off my remote? It is completely not working. The Activities button is light up and it simply says Harmony Safe Mode.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode.
2. Update the firmware. Update the configuration. If you are unsure of how to do this, please see below.
- Upgrading/Reapplying the firmware on your Harmony Remote
- http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration (update the remote).
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration (Update your Harmony remote).
May 06, 2010 | Logitech Harmony 520 LCD Remote Control
Logitech Harmony 670 remote stuck on Safe Mode. How do I get out?
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
2. Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration. Did this fix the problem? If no, please e-mail us back for further information about your issue.
ANSWER:
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 31, 2010 | Logitech Harmony 670 LCD Remote Control
Stuck in safe mode
FIRMWARE:
Jan 27, 2010 | Logitech Harmony 520 LCD Remote Control
My Logitech Remote 550 is Locked in the Safe Mode. How do I get it our of Safe Mode.
Doing a firmware upgrade is the BEST way to recover from Safe Mode. A remote may go into safe mode itself for a variety of reasons.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Hope this helps
Sep 24, 2009 | Logitech Harmony 550 Remote Control
Harmony 550 in safe mode
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
Aug 29, 2009 | Logitech Harmony 550 Remote Control
It says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
I hope this helps!!!
-Kennedy
Aug 05, 2009 | Logitech Harmony 550 Remote Control
My harmony is stuck in safe mode
I had the same issue this morning so my apologies for the delay in answering you. After numerous delays and frustrations in being unable to "update" my remote i did the following. First, remove all batteries and disconnect remote from the USB cable. Check ALL buttons to ensure that none are stuck in the down position. I found that my SELECT/OK button was stuck in the "on" position. Continue to check all buttons to make sure all test fine. After doing this hold down the "Off" button while connecting the USB cable, still no batteries in the unit at this time. Hold the "Off" button down for at least 10 seconds or until the units Testing is completed. If the Harmony remote software is up, perform the Update Remote step still sans batteries. After it completes it may perform a self test again (mine did) and after it completes then insert the batteries back into the unit. Hope this helps.
Nov 27, 2008 | Logitech HARMONY 659 Remote Control
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
