Question about Water Heaters
How do i reset my high temp switch on my rheem super quiet 80
  • 588 Answers
SOURCE: I have a Rheem Classic Series Super Quiet 80 gas
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Posted on Jan 05, 2010
SOURCE: Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
Posted on Jul 17, 2010
heatman101
  • 43501 Answers
SOURCE: i have a rheem classic
no just repalce all the covers and then cycle to power to the unit and it should take off and go...be aware that the t-stat could take five minutes or so to recycle and star the unit also..
heatman101
Posted on Aug 11, 2010
SOURCE: Rheem classic super quiet 80.
YOUR TEMPERATURE SENSOR NEEDED .
CLEANING, LIGHT SANDPAPER WILL DO THE TRICK.
IT LOOKS LIKE AN UP RIGHT NEEDLE ATTACHED TO A SMALL WHITE DISK. http://alltemp.com/FreeInHomeEstimate.html
Posted on Mar 05, 2011
  • 133 Answers
SOURCE: Hi- how do i add
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know. Roger
There are service ports on the ends of the two copper lines at the condenser. Be VERY careful not to get any air in the system. Air carries moisure which will create acid and destroy the system. Don't touch the the smaller line. Pressure there is usually over 200 PSI. You sound like you have done this before. If not, let me know. Roger
Posted on Apr 10, 2011
How to reset gas valve on a rheem classic super quiet 80
Depending on the specific setup, there should be a reset in the gas line. Either a push OR pull button.
Dec 26, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
RHEEM RTGL 74 XP FLASHING 80 AND CL
I know this is late, but I just went through this problem right now, or rather just a few minutes ago, after finishing the installation.
What worked was holding the up and down arrows together, this is usually what resets other electronics. Well, it worked. It caused the unit to reset and everything started working properly.
Again, while I know this is a late answer for you, I hope it helps others that were looking for a solution and could not find one, like myself tonight.
Sep 14, 2012 | Rheem Tankless Hot Water Heater...
Sime super 80.. Heating and hot water at the same time?
going off on a safety possible high temp unit needs service such a nozzle filter if oil or thermocouple if gas
Jun 16, 2017 | Water Heaters
I have a rheem classic series super quiet 80 furnace. when the panel that covers up the control board is removed is there a reset button or sequence that mut be performed so the system will once again run.
heatman101
Aug 11, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Rheem Classic Series Super Quiet 80 gas furnace. My problem is the furnace will turn on burner fires for a couple of seconds then burner turns off and fan blows. This cycle cotinues and eventualy...
Dec 29, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
49 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
