Question about Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc Model
I have the rheem super quiet 80 and is blowing cold air rather then hot,i changed filter but dont know where the high temp reset is
    Master:
  • 522 Answers
Heating element, REALLY? Your gas furnace has high temp limits around the burners, heat exchanger, and probably the blower also. The little switches have 2 wires connected to it, and a small reset between the wires. Should have a little red dot/color on the push button that resets. I'd suggest calling a professional.
Posted on Nov 23, 2017
    Top Expert:
  • Rheem Master
  • 6,889 Answers
Heating element
4 Suggested Answers
  • 588 Answers
SOURCE: I have a Rheem Classic Series Super Quiet 80 gas
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: i have a rheem classic
no just repalce all the covers and then cycle to power to the unit and it should take off and go...be aware that the t-stat could take five minutes or so to recycle and star the unit also..
heatman101
Posted on Aug 11, 2010
Car heater blows cold air
The coil is blocked my friend
You need to clean it out car manufacturers never put filters
Jan 04, 2014 | Cars & Trucks
How to reset gas valve on a rheem classic super quiet 80
Depending on the specific setup, there should be a reset in the gas line. Either a push OR pull button.
Dec 26, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
How do I open the Rheem Super Quiet 80 to access filters?
You must pull the top door off first for it sits on the bottom then remove the lower door and the filter should sit underneath the blower housing, push in and pull up on the wire filter snap being careful not to unhook it in the back of the air handler cabinet, then remove the filter, to re-install follow removal in reverse.
Sep 23, 2011 | Heating & Cooling
Hi, I ahve a Rheem Classic Plus Series SUper Quiet 80 Unit and no air is blowing thru the vents but the inside/outside units kick on? can you help?
Is the inside fan running? If it is then check your air filter. If it isn't, turn off power to the inside unit and see if the fan turns freely by hand. Next check the capacitor for the indoor fan. Does the fan on this unit connect to a circuit board? Set the thermostat to make the air come on and check for power where the fast speed wire connects to the circuit board and neutral. If it's not there, the circuit board is probably bad. You can look at the back side of the board to see if any traces are burnt off. Let me know what you find.
Aug 13, 2010 | Heating & Cooling
Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
May 23, 2010 | Heating & Cooling
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
Heater blows cold air when it is 30 degrees out side
heat pumps don't work as effient at that temp thats why they have 2nd stage supplemtial heat
Jan 09, 2009 | Heating & Cooling
96 audi a4 blowing cold air
yes, very possible. but first check your fluid level, thermostat.
Dec 06, 2008 | 1997 Audi A4
My train air unit cools at night but during the heat of the day it takes all it can do to keep the apartment around 80 degrees the maintnance man at work said the low pressure was at 80 and the high was at...
with that reading on the psi it sounds like it's doing all it can. maybe too small or lost it's capacity to cool your home.did it do ok last year? is the ducting ok? may need a pro to ck it dan
Jul 23, 2008 | Heating & Cooling
Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc Model Logo
97 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
