Question about Coffee Makers & Espresso Machines
My Jura Ena 3 is leaking from the bottom whenever I make coffee. It seems to be coming from a hole towards the back of the machine. Any ideas?
    Top Expert:
  • Coffee Maker... Master
  • 49,094 Answers
Usually not repairable . BIN it
Posted on Dec 11, 2016
My Jura Ena 3 is leaking out the bottom.
First I'm not a JURA tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
*** the following is for information only. ***
* If your leaking at or under the water tank then check for crack or you may be missing a rubber seal, o-ring, or washer. Replace the whole tank as a unit.
* If your leaking into the dregs or drip tray then there is a problem with the brewing system. Call for service. They may need to replace the brew valve or PC board.
* If your leaking at the bottom, drip tray, or side only when the pump buzzes (pumping water) then there is a cracked or disconnected hose line or fitting. Call for service and replace.
* If your leaking when the steam wand is in use then there is a similar problem with the 2nd pump system. Call for service and replace.
* If your leaking liquid coffee into the dregs tray or drip tray. Then you have a worn or missing group gasket(s). Call for service and replace. (you may find gasket kits from or online.)
* Final; Leaking water and electrical equipment is not a good idea. Best to be safe. Unplug and call for service.
Aloha, ukeboy57
PS: I've found the following video of a look inside the Jura;
Feb 03, 2018 | Coffee Makers & Espresso Machines
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Jura ena don't grind coffee
new grinder teeth
Dec 27, 2013 | Jura ENA 3
Ena 3 troubleshooting: Right now it appears that the right coffee spout has a weaker flow than the left. Is it clogged? How can I fix it if it is even broken. Thanks!
Got it! It took me two months and the parts diagram to figure it out.,%20ENA%205%20Diagram.pdf
Use a water-flosser... I used like 8 full water tanks and DONE.
The simpler way would be to try to point up the water-flosser through each of the four holes of each spout... It will be a mess but it should work.
The other way:
1.- Take the grey plastic panel out from the front dispenser. Use a small flat screw-driver, start from the top, there are 2 clips, and then 2 other clips on the bottom.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-0.jpg ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-2.jpg 2.- You will see the dispenser "inside", a two black tubes with the spouts at the end and an air intake (I guess) on top. Take out the air intake, that will let you have access into the tubes with the water-flosser.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-9.jpg 3.- Take your time "flossing" your dispenser, as I said it took me like 8 water tanks... a lot of coffee residual got accumulated (to my surprise).
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-14.jpg 4.- Voila!
Jan 29, 2011 | Jura Capresso Jura Ena 3 Espresso Machine ...
Coffee Makers & Espresso Machines Logo
114 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
