I have a Rowe Ami r81 only the right speaker works properly the left one is a lot quieter not sure what to look for to solve the problem
  • 319 Answers
SOURCE: both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Posted on May 01, 2008
CykoMF
  • 3 Answers
SOURCE: rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Posted on Sep 16, 2008
  • 195 Answers
SOURCE: Rowe AMI R-92 Error 4
Error 4 relates to the battery on the Central Control Computer (CCC) is low.
The battery (B1 3 volts lithium) needs replacing, you will need to note all the settings on CCC so they can be inputted after the battery is replaced.
Regards
Alan Hood (ami-man)
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
alan-hood@datex.co.uk
Posted on Feb 27, 2009
Fixitman909
  • 430 Answers
SOURCE: 02 pontiac grand prix front end roar started about
engine drive shaft bearing is bad...u have from motor. left and right side shafts. and each side has a inner by motor and a outer by wheel bearing so 2 bearings on each side.. replacing both...on either side.saves from having a second job done later
Posted on Jun 26, 2009
  • 31 Answers
SOURCE: Right front speaker channel has a lower than usual output...
very basically try swapping over the speaker cables, if this doesnt work i suspect you are in need of a new ouput i.c. these can go if the speaker wires are touched together, unless there is a protection circuit.
Posted on Jul 19, 2009
I have a Rowe AMI 100 cd jukebox. The right side speaker will play for about 3 songs and then go out. Other speakers continue ti work. Is this a speaker problem or something else?
Make sure all the wiring is secure, you may have a bad coil on the speaker, then you need your amplifier checking by someone competent
May 01, 2014 | Wurlitzer Jukebox CD Player
I have a Rowe AMI 100 CD jukebox. It plays about 3 song and then right upper speaker goes out. Is this a speaker problem or something else?
You could have connector problems on the speaker crossover network located inside the amplifier compartment on the opposite wall from the amplifier. Typically the solder joints go bad where the connectors are soldered to the board. Usually a simple resoldering can fix it. There could also be problems with the connectors at that particular speaker itself.
Can auxiliary speakers be added to a Rowe/AMI Model CD 100K? If so, where do they connect?
Yes they can. Above the amplifier compartment you should see the output package. The output package is where the phono speakers are connected to but this can be used to provide output to extention speakers. E1 to E7 tappings left and right provide outputs at different voltages/wattage. E1 left and right is the comon (or ground connection) E2 is the lowest tapping and E7 is the highest. Most people would connect extention speakers to E3 or E4 left & right with the comon connections of the speakers to one of the E1's.
There is also connections for 70 volt line speakers, these are used where long cable runs are needed and the speakers are then fitted with 70 volt drop down transformers to the correct wattage of the speakers. These are available from most good electroic suppliers such as R.S. or Maplins etc.
Regards
Alan Hood
ami-man
Uk
Oct 07, 2010 | Vintage Jukebox External Speakers Shelf...
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
In the UK contact me
Alan Hood
ami-man
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
I have a Rowe AMI 100CD jukebox. Its making a loud buzzing noise when I plug it in. Everything else works except the loud noise that I have to unplug it right sway. Do you think it is the red button fuse,...
Hello camillemario,
The problem sounds as if there is a fault on the amplifier.
Pull the 110 volt plug from the power supply that feeds the amplifier.
If the amp is at fault and you are in the USA I would contact Bruce Wentworth for a test/repair to your amplifier.
Regards
Alan Hood
ami-man
UK
Feb 21, 2010 | Wurlitzer Jukebox 1015 One More Time...
Looking for a spare plastic piece for a Wurtlizer 1015 One More
Hello Belinda,
Check out www.victoryglass.com for spare parts for your one more time jukebox. Make sure that yours is Wurlitzer and not a Rowe Ami, Rock Ola or Antique Apperatus (they were a subsidiary of Rock Ola but used Rowe Ami parts).
Also in the UK Sound Leisure made the one more time.
Regards
Alan Hood
ami-man
UK
Feb 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Rowe Ami R-80 imperial jukebox
Hello Andy,
Yes I know the 1976 Rowe Ami R-80 jukebox very well as well as most of the other Rowe Ami jukeboxes.
The turntable motor and the lighting work off of the 110 volt output from the power supply.
The other power voltages are connected to the power supply via the molex plug.
Pin 1 30VDC white/red
Pin 2 30VAC yellow/black
Pin 3 Common black
Pin 4 Ground gren/yellow
Pin 5 No connection
Pin 6 Common black
All the voltages are protected by circuit breakers.
I assume that you may be in the UK if this is the case here are my contact details.
Alan Hood (ami-man)
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Jan 20, 2010 | Vintage Jukebox External Speakers Shelf...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
Rowe AMI CD100 RAM Error
try this turn the box off , hold down the 0 and the 1 selection button
at the same time turn the box on. that reloads the prom to the ram
Apr 01, 2009 | Audio Players & Recorders
66 people viewed this question
 Grubhead
Grubhead
