Furnace making a beeping sound then began blinking and heat not as warm as it was, it is a 1500 watt Comfort Zone infrared heater.
Benimur
  • 6966 Answers
SOURCE: A thermostat versus an AC problem
"outside sensor error" is indicative of a Diagnostic error display, a feature where the device checks the functionality of each attached component. It would seem that your system has the optional "Outdoor Temperature Sensor" (probably P/N TSTATXXSEN01-B). The error then indicates that either that sensor is faulty or the hook up cable is unplug or defective. If you do not observed any critical changes in the comfort inside your home or the area that your system monitors/controls, then this only confirms that it is external and a sensor problem and does not affect the A/C and/or the variable speed furnace/comfort zone system. Normal faults could be the external sensor to cable connector/terminals being exposed to the elements and would require hard cleaning.
This sensor is not critical to the operation of the system and is optional.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
  • 25 Answers
SOURCE: ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Posted on Nov 22, 2008
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
farfield
  • 462 Answers
SOURCE: Carrier Comfort Zone ii - trying to find user manual
Your description leads me to believe you have 2 thermostats. How long have you lived in the house? Did it work for you lately? Sometimes its just the door switch. If you have to remove it to change the filter or had it off for another reason hold the switch in by hand and try it. then check the door for correct channeling in the grooves provided and see if this is it.
Posted on Mar 10, 2009
SOURCE: dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Posted on Jan 22, 2010
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
What is the A05 message mean?
A05 overheat condition, you must clean thoroughly,
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
