Question about Canon 3225 Copier
Cannon ir 3225 copier paper gets jammed near the heater unit when printing from A4 tray. pls help.
  • 270 Answers
SOURCE: repeated paper jam in the fuser unit
There could be two problems with the copier:
1. There has been a Canon mod for the two pads already suggested earlier. Remove the two pads and place a foam strip that is runs across the top of the lower right access door basically between those two pads. This creates more even pressure across the deflector for the upper paper cassette.
The style of roller above the exit for the paper cassette is now gray in color instead of black.
Posted on Nov 13, 2007
  • 4402 Answers
SOURCE: ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
Posted on Sep 03, 2008
  • 56 Answers
SOURCE: i have d760 cannon copier. finally removed the
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Posted on Oct 24, 2009
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
  • 1219 Answers
SOURCE: in A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Posted on Jan 13, 2010
Cannon IR 1600 Rec paper jam any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Copier keeps giving paper jam on A4 sheet feed although no paper is jammed. A3 Feed is no problem. Is tthere sensors that need cleaning etc??
please pull the tray out and check machine properly .may be there is any small piece of paper .remove it check machine from inside and fuser unit also..if the problem stills check all sensors by manually moving and cleaning ..problem will be solved
Sep 24, 2011 | Canon iR 2022 Printer
The canon ir 3225 gives me error e 000280 - 000 code please assist
i have the cannon ir 3225 and i use id management & pasword but i forgot the management id and to riset pasword and solve the problem
Sep 06, 2011 | Canon imageRUNNER 3225 Black and White...
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
Mar 15, 2009 | Canon imageRUNNER 400S Copier
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
Related to fixing
ok so were are you feeding the A4 paper from if from the bypass you need to select A4 size or free in the settings for the bypass tray
Dec 26, 2008 | Canon imageRUNNER 5000 Copier
Canon 3225 Copier Logo
old marine
old marine
