Question about Zanussi Washing Machines
I have a zanussi lindo 300 I can't turn Child lock off and programme won't start. Pic shows light that's on and I don't know how to turn it off
  • 8 Answers
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Posted on Jul 30, 2008
  • 15 Answers
SOURCE: All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Posted on Jan 12, 2010
  • 6277 Answers
SOURCE: how do you turn off the child lock as i can't
Press and hold the child lock button for more than 3 seconds should release it ;-0)
Cheers,
John C
Posted on Mar 27, 2011
  • 6277 Answers
SOURCE: Zanussi ZWF16381W. The wash stopped mid-cycle
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
  • 4 Answers
SOURCE: zanussi iz16s door does not lock once programme
give it a swift kick, that should do it... or tip in on its side... and if that doesnt work just burn it and cut your losses!!!
Posted on Oct 29, 2011
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
I have a Zanussi Lindo 300 and can't change cycle child lock showing have tried everything but not coming off duvet wash help please
try unplugging machine and leave for at least 5 mins. this should reset the system. other than that you will need to call out a service engineer.
Sep 19, 2016 | Zanussi Washing Machines
When using Delicate cycle machine does not drain fully. How can I empty machine before next wash Zanussi Lindo 300
sometimes small items get over the edge of the tub & as you said can plug the pump, most get caught in the hose
Feb 12, 2015 | Zanussi Washing Machines
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Lost child lock code and it's asking for it...,.HELP?
If the previous user never used a child lock function, how do this now activated? Anyway, to reset this set, you have to know about the child lock code. There is some details about, how to unlock the child lock, its repair manual will have the procedure. Check this link. It has details about these matters to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 22, 2013 | Daewoo DTQ-13P2FC 13" TV
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
Machine on / off button flashing - unable to start it?
Yes indeed the child lock in on, Try pressing it in and hold for 5 secs to clear, any further problem please let me know...
Nov 24, 2011 | Zanussi Washing Machines
Jan 12, 2010 | Washing Machines
Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
155 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
