Question about De Dietrich Ovens
De Dietrich DOD788B is not switching on. None of the digital buttons work except for the timer, but the clock is on.
    New Friend:
  • 14 Answers
Ovens can sometimes need a time set on the clock, it dose not need to be the right time but it must be at a time ie not flashing
Posted on Dec 11, 2016
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
Unlock control panel
Function switch must be in the "O" position
Press the " /\ " button for a few seconds until it beeps.
Then use the +/- buttons to set time.
Try powering off and switching back on again if that doesn't work.
May vary between models but De Deitrich do free manuals downloads. Just google it
Nov 10, 2014 | De Dietrich Ovens
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn
The part that needs replacing is the clock timer.
FIRST: ISOLATE THE CIRCUIT.
The front fascia is held on by three clips. Take off the two knobs and gently pry away the fascia fron the left, right and top centre.
The clock timer is held in by four plastic push clips at the top and bottom about 1cm in from the end. Push them in and pull the timer out.
There are now three wires on push clips attached at the back.
Do not take the colours for granted. On my oven just repaired the Live was Black and the Neutral was Red! The black marked 'C' is the input. The side by the trip switch is the output. The Red goes on the other side.
When the timer trips it causes the circuit between the input and output to break.
You have two options now:
Read the serial number of the timer and try and order it (expensive), swap the cables over.
Carefully run an electrical cable between the push clips on both black cables making sure you leave no exposed wire. Your timer and clock however will never work, the oven just does not care about it anymore.
Note: I am not an oven engineer, I am an electrical engineer in another field and have tested voltages and current and believe this to be safe. I have done this on my own oven.
Sep 12, 2009 | De Dietrich DOC310 Electric Single Oven
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Ovens Logo
53 people viewed this question
Top De Dietrich Ovens Experts
ashburton
richie46
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
