Question about Sewing Machines
Can u show me a picture were the upper tension is
  • Sewing Machines Master
  • 11,703 Answers
Search the internet for a manual:
Make Model manual
or contact manufacturer support.
Posted on Dec 11, 2016
    Top Expert:
  • 50,166 Answers
Suggest you search for it thru Google
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
Top thread showing on bottom using pe500
First, remove the upper thread. RAISE the presser foot and rethread the upper thread making sure the path is correct.
Retest the stitch. The tension is correct, both threads should meet in the middle of the fabric. If the upper thread is still showing under the fabric, slightly tighten the upper tension. Keep adjusting until the threads are where you'd like them.
Sep 23, 2016 | Sewing Machines
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
Why is the stitching on the bobbin side of soft fabric uneven
Is it the upper thread that is looping under the fabric? If so, that's what is called thread nesting or bird nesting. It is usually caused by it not being threaded correctly or the tension is off. Most likely, it is because the thread is either not in all the guides, the thread path is incorrect (it may have jumped out of the take-up lever), OR (most frequently) the thread is not completely seated in the tension disk.
#1--install a brand new needle that is compatible with the thread & fabric you are sewing. All About Needles
#2--remove the upper thread. Always raise the presser foot and rethread from the beginning making sure to follow all the guides and the thread pathway.
Set the upper tension to the midway point between high & low number and test. Re-adjust tension as needed. If the upper thread is showing too much on the underside of the fabric, the upper tension is too loose. If bobbin thread is showing on the top, then upper tension is too tight. Correct tension is when both upper & bobbin threads meet in the middle.
Apr 12, 2016 | Bernina Activa 140
Why is the bobbin thread bunching up?
if your saying that your bobbin thread is balling up under the platen plate , this is a sure sign that your top thread tension is not correct and there isn't enough tension to pull the bobbin thread up from below
Mar 24, 2016 | Sewing Machines
The bobbin thread shows to the front. Does the bobbin or thread tension need adjusted
Generally, tension adjustments are made using the upper thread tension. Most likely the upper tension is set too tight and is pulling the bobbin thread up. Loosen the upper tension and try again. Tension is accurate when the upper thread and bobbin thread meet in the middle of the fabric. Whenever fabric, thread & needle are changed, there may be a need to adjust the upper tension.
HINT: When threading the upper thread, make sure the presser foot is RAISED during threading to make sure the upper tension disks are open and the thread seats properly.
Bobbin tension is only adjusted when the tensions are way out of whack. Only slight turns of the bobbin case tension screw are made in graduated movements and testing occurs after each adjustment.
Jan 20, 2016 | Sewing Machines
How do you adjust or set the tensions
Make sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk.
The factory standard tension setting is the halfway point between the low & high numbers. Be sure you are using needle & thread that are compatible with each other and the fabric you are sewing.
All About Needles
Test your stitch on the fabric you are sewing. If the upper thread is showing on the bottom of the fabric, the upper tension is too loose. If the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
Ideal tension is when both upper and bobbin threads meet in the middle of the fabric. The tension will need adjusting anytime you change fabric weight, needle size, and thread weight.
Dec 16, 2015 | Sewing Machines
What should the tension be set at?
where ever it sews the best of course .do a few test pieces .
Oct 18, 2015 | Sewing Machines
I can not get the tension right - the manual is not helpful at all - please help?
Be sure to RAISE the presser foot BEFORE threading the upper tension. This releases the tension disks so the thread will seat properly.
Start out with the upper tension set at the mid-point. This is generally the factory setting. Then test and adjust. If the thread shows loops under the fabric, the upper tension is too loose. If the bobbin thread is showing on the top of the fabric, the upper tension is too tight. Test and adjust until the top and bottom threads meet in the middle of the fabric.
Sep 17, 2015 | Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
