Question about PfaFF Sewing Machines
Users is the upper tension on a pfaff 2140 - PfaFF Sewing Machines
  • PfaFF Master
  • 12,296 Answers
Generally, the factory standard tension setting is the midway point between high & low numbers. Then tweak for your particular machine.
Posted on Dec 11, 2016
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
Why doesn't it communicate with my Pfaff 2140?
sounds like there not compatable, have you checked with pfaff technical support about the problem,
here's their number
Toll free assistance - 1.877.746.4375
here is a link for their support page
Machine Support
Mar 22, 2016 | PfaFF Creative 7570
How do I remove the left cover on a phaff 2140. the piece that covers the tension discs.
Don't know this machine but would avoid pulling anything off as screws have a habit of pinging out and never going back. Try pulling a thicker piece of thread or fabric through the tension disks to dislodge whatever is there first
Oct 02, 2015 | PfaFF Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
Pfaff machine -sews with thread loops forming on the underside of the fabric.
This is usualy a thread tension problem. Adjust the upper thread tension first. If tightening the upper thread tension doesn't work, then adjust the bobbin holder (lower thread tension) check with the user manual for your specific machine for the correct procedure.
May 17, 2011 | PfaFF Sewing Machines
Pfaff 2140. Foot control will not work. Where
I can get new ones. You can email me at csews@email.com
Feb 27, 2009 | Sewing Machines
Pfaff 2140 - help
If this new computer system is Vista, there are reports of incompatibility from a number of users of different brands........I would suggest you contact the Head Office of Pfaff in your country and ask to speak with their training department, as they ought to have the latest information and advice.
May 23, 2008 | PfaFF Sewing Machines
Thread bunches under the material
There ARE still parts for your 7570 - amazing how rumors can get around!
Could be any number of things - from something as simple as a thread caught somewhere in the upper/lower tensions to the tension assembly to timing to any number of other things? You may have already tried some of these - hope this helps:
  1. Try "flossing" your upper tension - this is nothing more than running a heavyweight thread (such as upholstery or 12 weight thread) through the threading paths. Grasp the thread at the beginning of the threading path and the end coming through the needle and "FLOSS" (back and forth - just like you do your teeth). This will usually pull through anything that is gently stuck.
  2. Pretty much the same thing for the bobbin thread - if you're comfortable doing so, loosen the tension screw on the side of the bobbin case to make sure there aren't any little bits of thread fuzz stuck under the tension plate on the side of the bobbin case.
  3. Also remove the needle plate to allow you to better see the upper part of the bobbin system - if there are any bits of thread, etc. stuck in there, you may be able to see them and pull out with tweezers (turn machine off before you do this so the tweezers don't accidentally come into contact with anything).
If this doesn't work, you'll need to have a sewing machine tech look at it (I would recommend a Pfaff-trained tech as they're going to be the most familiar with your machine). The 2140/2144/2170 use most of the same parts - even the new CV still uses some of the same parts.
Good Luck,
Kim
Apr 11, 2008 | PfaFF Creative 7570
Sewing Machines Logo
52 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
