My STB1010Z decoder remote has failed to work even after replacing batteries
My STB1010Z remote has failed to work even after replacing batteries
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Dec 11, 2016 | Televison & Video
DSD 1131 does not respond to a new remote control which is exactly the same as the old one. the remote is not faulty because itworks with other decoders
Some remotes , while looking the same on the outside are much different on the inside. Example: Two remotes in a household with 2 decoders in different rooms. To eliminate one from interfering with the other, each remote is matched to its decoder.
Jul 24, 2016 | Televison & Video
My decoder is not responding to my remote. Every button I press on the remote, the yellow button on the decoder goes on. Please assist
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 31, 2014 | Televison & Video
My decoder Dstv dsd 3u doesn't response to the remote what should I do cause i need to add volume
If you have extra batteries, try to replace the old one and install the new batteries. And if still doesn't work, try to clean the battery terminals of the remote control, because sometimes, those are the one that making the problem due to corrosion caused by leaked batteries.
Aug 04, 2014 | Televison & Video
Sharp aquos remote not working
the polarity of the batteries in case the monkeyed with them.
Remove the batteries from the remote, unplug the Power to the TV, reinstall remote batteries taking care the polarity of the batteries in case the kids monkeyed with them and then plug the power cord back into the TV.
If that fails, take the remote to the store and and see if it works on their Sharp TV like yours. If that fails contact Sharp support for a replacement. (1.800.BE.SHARP)
Dec 17, 2013 | Televison & Video
RCR remote is not working! Randomly stopped working
These have tiny fuses inside that need replacing. Check out sites like Makezine, Instructables and Zedomax for solutions to hack or repair your handset.
Even new batteries fail. Sometimes it can be just the one battery that fails. Get an electronic battery charger that allows you to recharge ordinary batteries or a multimeter to check the current of your batteries. With a multimeter you should be able to check the resistence for any breaks in the PC Board from the battery compartment.
Dec 12, 2009 | RCA Televison & Video
Cyberhome dvr1600 remot
try replacing the decoder.. i have same problem but i solved it by replacing the decoder... the new one..
Mar 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
