Question about Dryers
Smart meters do they remove old gas ando electric meters because there is not much room in our hall cabinet
  • Dryers Master
  • 3,228 Answers
The idea is quite amusing... SAFETY, ACCESS & VENTING
(these are not things I usually find lumped together)
that a utility would care about the spaciousness of a hallway... but
IF...(I say this for questions that give me the feeling I need to wrap my brain in TIN-FOIL)... they got moved...
It was because a code required THREE FEET in front of a SERVICE ENTRANCE... NOT for the AGENTS to be able to see and hear everything better (for recording purposes (spying)).
The UTILITIES JUST want to see a more beautiful world... (not)...
Saves them MONEY... (tons)
Not having to have HUMANS read your meters...!!
Your higher rates... cost them a lot less to charge...
with their NEW (probably imported) "smart" meters).
Profiling your every action in your home is just a HAPPY BY-PRODUCT.
BIG BROTHER
Carnac the Magnificent
Posted on Dec 11, 2016
    Top Expert:
  • Dryers Master
  • 52,135 Answers
You will have to contact the electric and gas companies for that .
Why does my money not go on my smart meter strate away it does on the electric but not on the gas
It has to clear at the gas company then they turn it on from there. The electric is directly switched because it wont blow up if there is a problem with the switch.
Thats the best and least complicated answer i can give.
Nov 06, 2015 | Smart Cars & Trucks
DCVH660GH0WW
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Aug 22, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer is not blowing heat
Aug 17, 2014 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
Jul 04, 2014 | Kenmore 500 6952 Dryer
My gas kenmore 80 series is not heating?
May 20, 2014 | Kenmore 80 Series Heating Element -...
My shop was closed for 6 weeks during Christmas and New Year period ie half of my business period did not have any electricity consumption. However, my electricty usage was the same as the previous...
you did not mention what sort of business you run
if it has commercial fridges or cool rooms , they still use power
if it was a book shop the power consumption would be about 90% less as all that would be running is the security lights and security systems
smart meters can be circumvented so get in a qualified electrician to check that power is not being stolen and then get in a lawyer
Aug 16, 2017 | Computers & Internet
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
We have an air make up unit on our community hall with no heat
Depending on the outdoor temps, 10 kw won't heat much. If you have a multi-meter you can check the amp draw as well. You should get 20 amps for each heat strip. Each heat strip is 5kw.
Mar 23, 2010 | GE Built-In Room Air Heat Cool Air...
Frigidaire FRT045GM freezer works but fridge does not
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today.com...let me know
Jan 03, 2010 | Refrigerators
How do you chance the burners?
All you need to do is get the same length. Just remove the old ones by lifting them out after removing screws. Slide the new ones on the valves. NOTE: look at the air gaps on the air curtains on the old burners and try to match them to the new burners.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 01, 2009 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Dryers Logo
55 people viewed this question
Top Dryers Experts
