Question about Pioneer VSX-519V-K 5-Channel A/V Receiver Black
How to connect my microphone to pioneer receiver VSX-519V And connect to tv
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
  • 49 Answers
SOURCE: Pioneer VSX-519V was hooked up to TV unit was on
a thump or surge caused the fuse to blow. unplug the RX - remove top cover and replace fuse.
Posted on Mar 04, 2010
  • 88 Answers
SOURCE: my pioneer vsx-519V-k amp keeps turning off
check audio ic & component like resistors & capacitors. good luck!
Posted on Apr 26, 2010
caroldon
  • 17129 Answers
SOURCE: My pioneer vsx-519V-k amp won't turn on. Just
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
Posted on Jul 06, 2010
tbreeze47
  • 3083 Answers
SOURCE: My remote control quit working.
The first thing to try is to clean the battery terminals inside the remote with a qtip and at least 90% isopropyl alcohol, or a pencil eraser. Do the same for the battery terminals, and see if this fixes the problem. If you push the remote buttons while aiming it at a digital camera, you will see a white light, and know that the remote is working. If it's not working, you might be able to find a universal remote to take it's place.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 18, 2010
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
No sound through headphone or speakers
google your wire harness for ur car and make sure your connections are tight and hooked up rite
Sep 17, 2013 | Pioneer VSX-519V-K Surround A/V Receiver
Can't hook up my turntable to my pioneer reciever VSX-519V,I see no hook-up for it!
You need to have a turntable with a built-in preamp. The receiver does not have a phono preamp in it like the older receivers did.
Mar 04, 2013 | Audio Players & Recorders
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Oct 28, 2012 | Pioneer Vsx 519v-k 5.1 Home Theater 550...
Turn it on and it turns back off
it sound like the dsp ( digital sound processing) board is not working, take it to your nearest pioneer shop and get them to take a look at it, hope this helps
Dec 26, 2011 | Pioneer Audio Players & Recorders
How to hookup micro phone to Audio/video multi channel reciever model# VSX-D411
It doesn't support direct connection of a microphone.
Register and download the manual for free at hifiengine.com
Search for "Pioneer VSX-D412"
Mar 06, 2011 | Pioneer VSX-D412 Receiver
My pioneer vsx-519V-k amp won't turn on. Just bought it about 4 months ago. we were using it with music and a microphone when it conked out and won't turn on anymore. Have checked the power source, the...
Jul 06, 2010 | Pioneer VSX-518-K Receiver
My pioneer vsx-519V-k amp keeps turning off when I, turn the volume above 50 db
Apr 26, 2010 | Pioneer VSX-518-K Receiver
Pioneer VSX-519V-K 5-Channel A/V Receiver Black Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
