Question about Candy Washing Machines
Candy washing machine making really bad noise when spinning
  • 2,008 Answers
Check for drum bearing play wear
Posted on Dec 11, 2016
Candy grand o go482/2-80 very noisy when spinning
The manufacturer, "Candy Products" http://www.candy-domestic.co.uk/about_us/Default.aspx is more likely to provide an authoritative answer than anyone else. They seem to manufacture their own machines, answers based on experience with other makes and models are of no value to you in regard to this question.
the foregoing aside, what one man has made, another man can also make, or repair. It is extremely unlikely that Candy paid to have an exotic one of a kind bearing made for this washer. However, even if the bearings are a common industrial part, that doesn't mean that removing and replacing them is easy or cost efective, or even the cause of the noise.
Unless you have more expertise than your question implies, perhaps you should ask to have a Candy repairman diagnose the noise and if your diagnosis is confirmed give you seperate prices for the bearings and the installation of same. From that you can discern how long the professional repairman familar with the machine would require to do the work, and you should double or triple it to estimate how long it will take someone unfaniliar with the machine to do it
Feb 12, 2012 | Candy Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Washer motor makes lots of noise as its trying to spin. Hardly spins at all with wet load. Spins slowly and still makes noise when spinning with drum empty. Does this mean the motor is bad or is it the...
If it is a really loud noise that drives you out of the house then probably a bad bearing. If that is the case then time for a new machine. Also check for something caught between the tubs.
Dec 02, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Makes a lot of noise when spinning, could be
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 31, 2010 | Candy CBL166 Front Load Washer
Making a noise when spinning like there a coin inside
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hdgket
Nov 29, 2009 | Candy CNW136 Front Load Washer/Dryer
My candy go1682 makes a very loud banging noise on spin,it almost sounds like a plane taking off. julie
Suspension/Damping stut has failed , you need a new one pronto
Worst case is that the inner drum has come loose from the mounting on the back
Oct 02, 2009 | Maytag MAH6500 Neptune Front Loading...
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Loud Loud Noise and a jumping machine on spin mode
hi it may be the belt problem ...better to change it thank u....
Jun 03, 2009 | Candy Washing Machines
Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Dec 11, 2006 | Candy AQ130 Front Load Washer
Washing Machines Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
