Question about Panasonic Televison & Video
Panasonic Plasma TV fault - Screen is working 100% but no picture or sound when I plug receiver or laptop in. Laptop recognises the TV when connected.
tvtek
  • 1284 Answers
SOURCE: no picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Posted on Mar 08, 2008
dante777
  • 623 Answers
SOURCE: Connect HP Pavilion dv2000 laptop to Panasonic Viera 42'' plasma
If you get your wallpaper to show on your TV, then you should be almost there.
  • Try to right-click somewhere in the desktop, choose "Properties" and go to the Settings tab. (Now you should be able to see both monitors.)
  • Click on the "Identify" tab to see which one is your TV.
  • See if "Extend my Windows Desktop onto this monitor" is checked.
  • Try to find a resolution that works with your TV by changing the values for the screen resolution.
Posted on Jan 03, 2009
circuitworld
  • 335 Answers
SOURCE: Panasonic TH-37PD25 plasma has no sound
If all of your connector cables are in good standing and your input/output ports are hooked up correctly, this may be an audio defect developing in the processor board. I can walk you through some steps to confirm this problem.
e-mail me: circuitworld@comcast.net
Posted on Feb 12, 2009
  • 166 Answers
SOURCE: Connect Laptop HDMI to Receiver to TV via SVIDEO
you need a different type of cable to connect to your tv.a s-video will fit but not work.can't remember the name but it has to have more pins.besides that port is for projectors and cannot be used for anything else.you need a converter box like the one in the link ::::: http://www.bing.com/images/search?q=laptops+s-video+cords&FORM=BIFD#focal=a85da1a40c404788d7e32f0bf01eab05&furl=http%3A%2F%2Fwww.cvs.k12.mi.us%2Ftiz%2Fimages%2Fsvid-cables.jpg
unless you got a big tv with a very good picture it isn't worth it.and a good graphics card in the comp.most tvs are fuzzy and unreadable.i've did it enough to know
Posted on Aug 05, 2009
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Why panasonic viera picture quality all blurred
If you are driving it from a laptop, and both the laptop screen and TV are on at the same time then the laptop will be sending a blurred picture to the TV.
Toggle the laptop's picture output so that only the TV is displaying an image.
Sep 05, 2014 | Panasonic Viera TX-L39E6B 39" LED TV...
I have been using my panasonic tv as a display to watch films on from my laptop via HDMI however now i am just getting a black screen. the TV recognises that the laptop is connected and so does the la
try holding the hdmi wire connecting to the tv port at a slight angle, if it comes on then the hdmi connection is damaged,do you have sound?
give the connection a wiggle and inspect the connection, maybe worth a reset?
Dec 09, 2013 | Panasonic VIERA Televison & Video
Want to connect my dell vostro 2510 to panasonic plasma. Am using 15 pin out to DVI adapter to HDMI input on panasonic. Laptop recognises tv, as it is listed in connected devices, but I can not see video...
Try to switch the video display from your laptop to the TV by holding down the blue function key by the space bar and depressing the key that has the blue CRT/LCD on it.
Jun 24, 2011 | Dell Vostro 2510 Notebook
We have connected our asus K52J lap top to our panasonic viera plasma TH-P50V20A via a HDMI cable . We have picture ON THE TV but sound from our lap top only. How do we get sound from our TV
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Jan 03, 2011 | Panasonic Viera TH-50PX80U Plasma TV
I have a Panasonic Viera TH-50PX60U Plasma Picture Problem. The TV picture screen is showing up as purple. If i unplug the blue cable, the tv shows in black and white. If i plug in the cable, the...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 24, 2017 | Televison & Video
No picture on TV with Dell Inspiron 6000
the problem is your video configuration its supposed to be Tv-in on computer so you can receive video on the laptop screen
Jan 25, 2010 | Dell Inspiron 6000 Notebook
When i connect my hp laptop to my panasonic plasma tv thru a hdmi connection the screen resolution is to large and a i get no sound
Hi, you probably won't get audio from the HDMI port on a laptop post the exact model so I can check for you, you can get an adapter from the audio out to the in on the TV, as for the resolution, lower the resolution on the laptop before connecting it, simply right click the mouse anywhere on the desktop, then left click on properties then settings, then pull the resolution level to 800x600 save by clicking apply and OK , try a few settings to get the highest resolution the TV can display correctly.
Thanks
E
Aug 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
Jan 03, 2009 | HP Pavilion dv2000t Notebook
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
