Question about Hoover Vacuums
I'm looking for a powerhead to my hoover windtunnel royale vacuum model num 9010hp
  • 4 Answers
SOURCE: Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Posted on Apr 28, 2009
  • 199 Answers
SOURCE: My hoover U5720950 windtunnel bagless vacuum loses
when you lower the handel it is pinching the vaccume line constricting suction
Posted on Jun 11, 2009
VacuumRepair
  • 438 Answers
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
VacuumRepair
  • 438 Answers
SOURCE: Replace belt for Hoover Windtunnel Turbo Power
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Posted on Mar 21, 2010
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
Service manual hoover windtunnel u 6485-900
http://www.vacshopusa.com/windtunnel.htm
it is cost $4.99
Dec 06, 2012 | Hoover U6485900 Bagged Upright Vacuum
I need a new bag for the Hoover 3.8 Model # U5465-900 which bag is it ?
Hoover Genuine Hoover Type Y Allergen Filtration Vacuum Bags, Fits Hoover Windtunnel and Hoover Tempo Bags Hoover 4010100Y
Feb 17, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Chris Jones
GoVacuum.com
Dec 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The head on my Hoover Canister vacuum has stopped working
It sounds like the power connection pins, from the handle tube to the powerhead, are not making connection. The pins could have been damaged when you impacted it.
Nov 20, 2009 | Vacuums
Is there a manual for the hoover windtunnel Mach 3.8? thanks
if you go to hoover.com and look under download manuels. when it asks you for the model num. for your machine, put it in and push enter/search. if it's the pic. that i see and model num. U6437-900, you will need to put U6439-900 instead.( when putting in the model num. you don't have to put the dash in) i've checked for you and your model num. doesn't show, but the one that i have provided will be almost the same one has yours, but maybe a color difference and some tools extra. the manuel should work for you though. hope this helps
Aug 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
26 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
