Question about Mitsubishi Televison & Video
Mitsubishi hd projection error code blinks two times
The tv is 1080 hd
  • 3 Answers
SOURCE: Mitsubishi HD TV 1080 blinking green light
sounds like it has a bad DM assy, or a bad 9v reg ic.
the dm can be repaired, there are 4 capacitors on it that need to be replaced.
Posted on Dec 13, 2007
SOURCE: Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Posted on Jan 22, 2009
Slinteriors
  • 8617 Answers
SOURCE: Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on Feb 15, 2009
SD Tech
  • 14553 Answers
SOURCE: Misubishi Medallion 1080
If this is a ws-65411: it sounds like one of the two STK-392-110 convergence IC's is bad; you need to have both replaced at the same time; I do this type of repair(done hundreds of them) and most can be done right in your home.
The two ic's can be purchased on Ebay for about 12 dollars plus shipping.
This is the slow time of year for TV repair shops--find someone in your area who knows how to do this kind of repair---here shops charge 3-4 hundred but I charge 200-250 total depending on brand of set.
Shop around and if they insist on "taking set to shop" keep looking---any good tech can do this repair in your home---MAKE SURE HE CHANGES BOTH of the IC's!
I do this here for free so if this has been helpful give me a vote here.
Posted on Aug 24, 2009
Testimonial: "very helpful"
ArnelM
  • 184 Answers
SOURCE: Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Posted on Dec 26, 2009
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
Every time I turn my HD 1080 series Mitsubishi on 2 1/2 seconds later it turns off by itself
ok, a model number would be helpful but:
when set turns off and green power light goes out: on the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and let both go.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
This is the error code and indicates where the problem may be---let me know what code you find and I will tell you what it means.
SD TECH
Apr 28, 2012 | Televison & Video
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
It won't turn on and we don't have a remote control. What can we do ? Mitsubishi Medallion HD 1080
not knowing model number I will suggest a few things: if green power light comes on for a few seconds and goes out:
On front of set press and hold both the Menu and Input (device) buttons at same time for at least 5 seconds and release both.
Power light should blink a two digit error code like 2 blinks,,2 blinks,, a pause and repeat it several times.
This is a error code that indicates what area problem is in, let me know what error code you find and I will tell you what it means----if set has been unplugged you will have to try to turn it on and let it fail before you go for the error code.
SD TECH
Mar 31, 2011 | Mitsubishi Televison & Video
Dec 25, 2009 | Televison & Video
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Dec 13, 2007 | Televison & Video
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
