Question about Compaq Computers & Internet
Test for s200 scanner says ud dll not found When i try to test the s200 compaq scanner on my system (windows vista os ) it gives a msg UD DLL not found. what can i do for that ??
  • 781 Answers
You will need to reinstall drivers go to drivers in control panel device manager one of them should have yellow mark on it right click it and update drivers.
if this does not work right click and go to properties details and copy exactly what come up then do a search for it
Posted on Dec 11, 2016
Installation challenge
cus ethis aint made for vista ok xp only
Jan 31, 2008 | Umax Astra 3400 Flatbed Scanner
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
Nov 19, 2012 | Compaq S200 Color USB Flat Bed Scanner
Does s200 scanner work with windows vista?
You may have to run this device in Window 98 mode
It may or may not work depending on the driver set and is it compatible with the Windows OS.
May 01, 2010 | Compaq S 200 Flatbed Scanner
Mine is Lexmark X3470 model. When i tried to scan using Imaging studio, the msg. msvcr71 dll was not found. Reinstalling this application may fix this pbm comes. The scanner does not work. only motoring...
You need to have this file, msvcr71 dll So go here,      Download the file. and then copy it to \Windows\system32\ also it won't hurt to put it in the Root Directory as well. That will at least eliminate that DLL problem may work now.
Feb 01, 2010 | Lexmark X5470 All-In-One InkJet Printer
Install desktop theme
Hi there! Here's a solution to your problem. If you're using Vista WITHOUT SP1, Step 1: Download the UxTheme Patch from here. If you're using Vista WITH SP1, Step 1: Download the UxTheme Patch from here. Step 2: Login as a user with Administrative privileges -or- have Administrative credentials ready (check under the keyboard for a slip of paper). Step 3: Navigate to %systemroot%\System32 Step 4: Right-click uxtheme.dll and click properties. Step 5: Take ownership of the file and close dialogs. Step 6: Repeat steps 3 and 4 for themeui.dll and shsvcs.dll Step 7: Right-click uxtheme.dll and click properties. Step 8: Give yourself (or group) Full Control permissions and close dialogs. Step 9: Repeat steps 6 and 7 for themeui.dll and shsvcs.dll. Step 10: Rename uxtheme.dll to uxtheme.old. Step 11: Rename themeui.dll to themeui.old. Step 12: Rename shsvcs.dll to shsvcs.old. Step 13: Copy patched files into %systemroot%\System32 Step 14: Reboot After you have applied the patch, you can copy the theme into your Windows/Resources/Themes folder!
Jun 13, 2009 | Microsoft Windows Vista Ultimate Edition
I am trying to install VISTA Transformation 9.0.1 ver
Hey K,
I have seen this error before! You must be trying to install the VTP on a Windows 2000 OS. I got it working way back in 2005 .
Download the dll file from
copy it in the windows directory and system and system32 folders.
This should allow u to install the VTP.
You are doing this at your own risk so better make a copy of your important data.
Please rate as fixed coz i know this works and show some appritiaction :)
Feb 25, 2009 | Microsoft Windows Vista Ultimate Edition
Umax Install
hardware problem. Hardware could not be installed with windows XP
Jan 22, 2008 | Umax Astra 3450 Flatbed Scanner
Computers & Internet Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
