Question about Tablets & eReaders
I have a Yamaha RX-V367 receiver and the factory remote does not work properly.
I have to push the power on/of button several times to get it to work as well as the volume up/down before it works. Once it works it seems to function normally until I leave it idle or sitting for several minutes and then again I have to push the buttons several times before anything will work.
  • Paul
    Paul Dec 11, 2016
    Fixed
    I read on one of the AV forums a few people had similar problems so I tried the same fix.
    Take the batteries out, remove the one small screw, separate the two halves of the remote, clean the rubber keyboard with soap and water, clean the circuit board with rubbing alcohol (I used Windex) put it back together and works like new now.
  • 2,189 Answers
The remote is on the way out replace it
mine have gone the same way from over use
Posted on Dec 11, 2016
Testimonial: "Actually mine has been exactly the same since I bought it 2 years ago used, no change. No worse and no better."
The word demo how do I remove it from a AKASO tablet it's in big red letters?
Factory reset it,
Power off completely
2. then hold down the volume down button
3. holding the button press the power on button.
4. if done properly you should have several android boot options
5. select "Factory data reset"
6. Done
Note: if the volume down did not work, try the Volume Up button
Oct 16, 2017 | AKASO Tablets & eReaders
I have a Galaxy Tab 2 10.1 and I wish to reset my password.
NOTE: You may have to wait 30 seconds-1 minute when performing each step.
If you don't want to lose DATA there may be a "Forgot password?" option in which case google will reset the password via your email. If this option is not there then follow these steps.
To perform factory/hard reset please follow those steps (you will lose everything):
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
  • Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
  • Allow several minutes for the reboot process to complete..
  • This is all i could find on the internet so not sure if its what you are looking for.
Nov 18, 2016 | Tablets & eReaders
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
How to reset, when my android zeepad won't work by holding start and volume same time, nor does the reset button do it
Many people say to push and hold down the Volume(+) and Power button at the same time. Push and hold for as long as twenty seconds until you see a green android with green text.
But, on some devices and some Android O/S versions it takes pushing and holding the Volume(-) and Power button and holding them both down for twenty seconds or so or until you see the green Android and text screen. This will show the Wipe Data/Factory reset option. Select this option by scrolling using the Volume(+) button and engage using the power button. Some devices give you a second screen with a list of *no no no no no* and one line of Factory Reset. Again, scroll to the Reset option using the Volume(+) option and select it using the power button.
If the above doesn't work, either your battery is dead or your device is dead.
May 15, 2015 | Tablets & eReaders
My nobis tablet is stuck on the nobis start up screen. How do I fix it.
If you Google NobisNB09 stuck on GO you will find many angry people who have the same problem. Rarely does the factory reset procedure work to fix it. IMO they have a problem with faulty internal SD chips. So, what I'm saying is you may not be able to fix the problem other than trying to get an RMA and sending it back for repair if it's still in the warranty period.
Here is the factory reset procedure.
1) press and hold at the same time both the power button and the volume(-) button.
2) keep holding them until you see the Nobis screen, Then it will go off. Keep on holding both buttons down for perhaps ten or fifteen more seconds and finally you will see a screen with some green text options
3) Among the options is one that says something like "wipe data/factory reset.
4) Using the volume (+) button scroll to it and then press the power button once to select it.
5) Another screen will come up with text options of no, no no for five or six lines with one that has a go ahead for the reset option. Again, using the volume (+) to scroll to the reset option and select it using one push of the power button.
6) you will get a reboot option.
7) reboot by pushing the power button, it will turn off.
8) Give it a minute or so and then push the start button and
hold it until you see the Nobis screen. Let it go and wait. If the hardware's OK it will go through the initialization routine which
should take several minutes. Anything more than about ten
minutes without going to the set up screen indicates you have
bad hardware such as a faulty internal SD memory.
One hint: turn off your wi-fi router so it can't connect to wi-fi.
It will boot up with the wi-fi ON and it will connect to any open
router it can find and commence to download updates for all the apps. This makes it take forever and can completely fill
up the available app partition memory and result in another failure to boot up next time.
IMO the Nobis NBOP is a POS! I have one so I know.
Apr 06, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Volume buttons broken how do i do a factory reset
there should be a pin hole by the on off butten use a paper clip put it in the hole and hold for a sec.
Jan 12, 2015 | Tablets & eReaders
Tablet Froze on Android Screen-PLEASE PLEASE HELP!?
its stuck on bootloop and might have to be re-flashed with factory firmware...
Mar 06, 2017 | Tablets & eReaders
Kurio 4s need help
You can perform a reboot by holding the volume + button and power button at the same time. Release the power button after 5 seconds but keep holding the volume + button until a screen appears with options. Press the power button to select reboot. Next you will have to scroll down using the Volume + button again to highlight yes and press the power button to select. If the reboot does not work, you many have to perform a factory reset using the same steps except you have to use the volume + button to scroll down to the factory reset option. Hope this helps.
Feb 26, 2014 | Tablets & eReaders
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
* Allow several minutes for the factory data reset process to complete.
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
How do I factory reset my Coby Kyros 1125?
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
Oct 17, 2017 | Coby kyros Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
