Question about HP Photosmart M425 Digital Camera
Transfer software not reading images on device
When i try to transfer pictures from camera to computer, the transfer screen says "no images on device to transfer" which there are over 100 images. what happened?
  • 11,896 Answers
Download or update your driver for you camera. then open your software, turn on camera, and then hook up via usb.
Posted on Jul 20, 2009
How to transfer images from computer to nikon coolpix
I don't understand why you would want to transfer pictures from the computer to the camera. Normally you transfer pictures from the camera to the computer. But, if you really want to restore pictures to your camera's memory, you can remove the SD memory card from your camera and transfer the pictures on any computer equipped with an SD card reader/writer. These devices are built into most Apple computers, many PC's and are available as USB accessories for all other computers. I have seen them for under $20. When you connect the device and insert your camera's SC card, your computer will recognize the card and treat it as if it were another hard drive. You will be able to read or write or drag and drop picture files just as you would with any other file on your computer. By the way; most professional photographers use this method to transfer there photos rather then transferring them using a USB cable from the camera.
Jun 27, 2014 | Nikon Coolpix 4100 Digital Camera
When I try to download most recent pictures I am forced to download all that are on camera
It depends on what software you are using to transfer photos from the camera to your computer.
If you install and use the "Camera Window" transfer software Canon included with the camera, you will see you have three modes to choose from, including the option to transfer just the photos on your camera that have not yet been transferred.
Connect the camera with a USB cable to your computer.
Power up the camera.
The computer will detect the camera, and open a dialog box offering you a choice of programs on your computer that can handle photo transfers.
If you choose the Camera Window software, it will open and present a menu with three choices of action. The first option is, "Import images from Camera." Select this.
Another submenu opens presenting these three options:
1. Import Untransferred images. (this is what you said you want)
2. Select images to Import. (manually select just certain ones)
3. Import All images (automatically transfers every image on the card)
Menu screenshot, Canon's "Camera Window" transfer software2d13ae76-841e-450d-995d-43cd3e2dd7e6.png
Camera Window is just one of many available image transfer applications you could use. They all do essentially the same three things outlined above, including "Import Untransferred images."
Canon included a couple other utility programs on the CD that came with your Powershot A490 camera. One of them, "Zoom Broswer EX" enables you to reload photos from your computer, back on to your camera's image card, if you want to do that.
Jun 04, 2014 | Canon PowerShot A490 Digital Camera
I have been trying to download my photos from Canon A540 Dig Camera - previously I would simply plug into my computer and instantly the Canon software would pick up I was trying to transfer images and...
What OS does your computer have? If you open the file explorer (Computer or My Computer), is the camera listed among the devices with removable storage? If it is, the problem is that auto-run has been turned off by Windows (this is a security issue) for removable media. (It applies to flash drives too.)
Treat the camera as removable media and either launch the software first and then choose File > Open > the camera or click on the pictures on the camera by opening the Camera folders. The software should launch if the default program association has not been changed. (In Windows 7, click Start > Control Panel > Programs > Default Programs.)
I hope this helps.
Mar 09, 2011 | Canon PowerShot A540 Digital Camera
I Can't see the pictures or even copy it when I connect it to the computer? what will I do? thanks. GODBLESSU!!!!!!!!
The solution depends upon the Operating System. There are many options for transferring the images from the Camera to the Computer. You can either use the supplied Software for transferring the images to the Computer or with the help of Windows Explorer.
Let's try to set the Camera in PTP/MTP Mode and check if it the computer detects the Camera as a Removable Drive. To set the PTP/MTP Mode, select the USB Connect option from the Main Settings 2 Menu of the Camera.
If the Camera is detected as a Removable Drive in the Computer window, then open the DCIM Folder to copy all the images.
If the Software is installed in the Computer, then the Import Media Files screen of the Picture Motion Browser appears automatically.
Click on Import option to import the images. By default, images are imported into a folder created in Pictures folder that is named with the date of importing.
This should help you in transferring the images.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
After I put the pictures onto the computer the pictures automatically deleted the pictures. Why would it do this and this is only the second time it has happened since I received the camera a year ago.
Deletion from the camera is an option in your EasyShare software. Open the software, click on TOOLS, then CAMERAS/VIEWERS. Towards the bottom of the screen you'll see a blue bar labeled CAMERA FAVORITES ALBUM PROPERTIES. Just below that is the option ALWAYS REMOVE UNPROTECTED PICTURES FROM DEVICE AFTER TRANSFER. To retain images in the camera after you transfer them, make sure that this box is unchecked.
Dec 11, 2009 | Kodak EasyShare C913 Digital Camera
Transfering the images
be sure about the source selected in the software, or try the old way and use your cam as a mass storage, it will be like any flash memory, go to My Computer and open the new drive !! and enjoy
Aug 30, 2009 | HP Photosmart M425 Digital Camera
No pictures
Have you checked the HP hep site?
Here is their suggestion
Introduction This document explains how to transfer images from the camera to a computer running Windows XP operating system by using a universal serial bus (USB) cable. Transferring the images Follow the steps below to transfer images from the camera to a Windows XP computer. Step one: Connect the camera to the computer
  1. Turn off the camera.
  2. The camera came with a special USB cable for connecting the camera to a computer. Connect the large end of that USB cable to the computer. Figure 1: Connect the USB cable c00878070.gif
  3. Open the rubber door on the side of the camera and connect the small end of the USB cable to the USB connector on the camera.
Step two: Transfer the images Choose one of the following methods to transfer the image files: Method one: Transfer images with the HP Photosmart software
  1. Make sure the HP Photosmart software is installed on the computer. If the software is loaded, then go to step 2. If the software is not loaded, click here to upgrade to the latest version of imaging and printing software (in English).
  2. If images on the camera are selected for printing or selected for HP Instant Share destinations, make sure the computer is connected to a printer and the Internet.
  3. Turn on the camera. The HP Import Photos software starts on your computer. If you have set the software to automatically transfer the images in the camera, the images automatically transfer to the computer. Otherwise, in the Transfer images from Camera/Card screen, click Start Transfer . The images are transferred to the computer, and then if there are any still images that were previously selected for HP Instant Share destinations, those actions are started.
  4. When the Image Action Summary screen appears on the computer, you can disconnect the camera from the computer.
Method two: Transfer images without the HP Photosmart software If you do not, or cannot, install HP Photosmart Software on your computer, you can still transfer images from the camera to the computer using the Picture Transfer Protocol (PTP) in Windows XP. Follow the steps below to transfer images.
  1. Turn on the camera. Windows will automatically launch a program to transfer the images.
  2. When the images have finished transferring, disconnect the camera from the computer.
  3. If you encounter problems, check that the camera USB Configuration in the Setup Menu is set to Digital Camera .
    1. While in Live View , press the Live View/Playbackc00591915.gif button, and then press the Menu/OKc00280209.gif button.
    2. Scroll to the Setup Menuc00595863.gif using the left/right arrow c00280208.gif buttons.
    3. Use the up/down arrow c00280207.gif buttons to scroll through the Setup Menu to highlight the USB option.
    4. Use the left/right arrow c00280208.gif buttons to change the setting to Digital Camera and then press the Menu/OKc00280209.gif button.
    5. To exit from the Setup Menu , press the Live View/Playbackc00591915.gif button.
  4. Reconnect the camera to the computer.
Mar 06, 2008 | HP Photosmart M415 Digital Camera
Driver software problem with Olympus FE-210
I have a almost same problem my olympus fe 210 doesn't save pictures and doesn't show my old pictures but on my computer doesn't read any files but when i want to see how much memory do i have it sas that is 736mb free
Jan 10, 2008 | Olympus FE-210 Digital Camera
Image transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 19, 2007 | HP Photosmart E217 Digital Camera
Image transfer to computer
Mar 06, 2007 | HP Photosmart E217 Digital Camera
HP Photosmart M425 Digital Camera Logo
139 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
