Question about Garden
Pto wont engage how can I hot wire for now to finish baling
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 8 Answers
SOURCE: PTO won't engage
If you look where your belt goes around the pulley on your pto, you will see your pto clutch. There are bolts with springs that hold everything together. Try tightening them 1/4 turn and then try it. If it still doesn't work, tighten it another quarter turn. There is a magnet there that might not be contacting properly. I have a 1605 and just had the same problem. You don't want to have to replace it , mine is like $400
Posted on May 04, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
Posted on May 24, 2009
  • 4 Answers
SOURCE: have ferguson TO 30 lever wont go in to live pto
Ferguson TO-30 did not have live PTO.
Posted on Sep 10, 2011
  • 6468 Answers
SOURCE: pto would not engage engine running
check the belt
Posted on Apr 03, 2012
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
Pto wont engage when mower is hot
your PTO is built just like a wound up coil and becomes magnatized it gets real hot and it shorts out when it heats up make sure you have no frayed wires which will creat a large risistance and really heat up
Sep 09, 2012 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
Dixon zeroturn DM 42 Pto will not engage.
did it burn out the clutch?or did you knock off the wires when removing the twine
Apr 07, 2012 | Garden
I have a 1999 cub 2135 with a kohler engine. the mower deck wont kick in . i ran a hot wire to the pto & it worked .do i have to replace the switch or the module. i also checked the seat switch &...
IF connecting that one hot wire to the pto made it engage then you either have a broken/cut/bad connection/wire to the pto or the switch is bad.
What you did by using the hotwire to the pto is bypass all the wiring and the switch for the pto.
You can determine if it's the switch real quick if it only has two connections/wires to the switch. Pull the switch, remove the wires and touch them together, after you have the mower in the condition under which the pto would engage. If the pto engages it's the switch for sure.
Take all the proper safety precautions. Don't let the wires touch anything else.
Sep 29, 2017 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Jun 21, 2009 | Garden
Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
May 07, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
