Comfortzone radiant heater cz530wm wont come on it acts like it has no power not even 9 mths old theres no power light or alarm light makes no noise
docjohn174
  • 943 Answers
SOURCE: My refrigerator is acting weird!
Hi. thanks for the question. I would check the fan motor, in the freezer. cut power to the fridge. remove back panel. replace the fan motor. clean all ice at the bottom of freezer. clean the drain ,from freezer to the back by the compressor thanks the appliance doc. please rate my answer.
Posted on Oct 07, 2008
  • 3600 Answers
SOURCE: water heater makes a constant hissing noise with power on or off?
You have a water leak under the house, but need to know if it's a gas heater or electric. check the Pop off valve on top of the tank it has a short handle and should go threw the floor pull up on the valve and let it sit back down, if it stops the high pressure pop off valve is leaking, you can buy it and replace it for 5 or 10 bucks, if that does not stop it look under the house. Also use a broom stick and put the round end at the wall and the other end near your ear and check the wall and floor for the noise the closer you get the louder the sound. Hope this helps. If you look under the house and see water you know you got a leak in the pipes or the tank itself.
Posted on Jan 05, 2010
  • 31 Answers
SOURCE: car wont start. has power, lights , alarm works.
take your starter off and get it tested sounds like your problem
Posted on Jan 16, 2010
SOURCE: Comfortzone heater displaying error message doFL.
According to the call line, hold down the up, down and enter buttons all at the same time and it should clear it. I took mine back and had it replaced so I never had a chance to try this.
Posted on Nov 19, 2010
SOURCE: comfortzone display ''dofl''
According to the call line you have to hit the up, down and enter buttons at one time. Did not try this as I returned mine before I got an answer. No problem with the new one!
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Why does this thing not run continuously and stay on long enough to heat up a room?
I would guess the over heat sensor has failed .contact the manufacturer customer support
Jan 25, 2016 | Windchaser Heating & Cooling
A friend gave me a Hayward Comfortzone pool heater several years ago, I have not used it yet but might, wondering how I could get a manual for installation and hook up etc.
Hayward no longer offer parts or any other support for the old Comfortzone heaters but you can follow the general guidlines from any of the Hayward heaters as far as gas line sizing, spacing requirements and piping. This one on the H-Series should work...
https://www.hayward-pool.com/pdf/manuals/Manual285.pdf
John
May 15, 2011 | Hayward Pool & Spa
Heater wont stay on. HELP!
Have the Hayward guys come out and prove to you that it is indeed low pressure and then get an estimate for repair costs. Assuming there is no warranty in effect, you might want to locate the heater manufacturer for guidance. They may have a website that may be of help.
Mar 20, 2017 | Hayward Comfort Zone Electric Spa Heater...
Car wont start. has power, lights , alarm works.
Jan 15, 2010 | 1997 Saturn SL
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
