Lightning hit power surge red light on but won't come on
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 11, 2016
Repair or Junk my Samsung UN55C6500VF TV?
Hi William,
Not necessary to junk your TV. Damages due to lightning are extensive at times but from what you have mentioned it appears that may be it is only the power supply board which has gone bad and rest of the TV is ok. Replacing power board may restore your TV.
Good Luck.
Aug 24, 2015 | Samsung Televison & Video
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
AOC Envision L32w761 TV. Lightning strike. Now nothing. Power light won't come on. Checked power to the Power Supply board and have it fine. Replaced TV and everything in the system looks OK. Bad TV...
If you are certain you have a lightning surge, almost anything can take down your TV. First check the obvious, do you have power coming out of the wall. Is the surge protector good, if you used one? If you have answered yes to the these questions, you may have acquired a power surge in your TV. You may not find it in your TV. As I have said it may be anywhere in the TV. You will need to take this TV to an authorized service center. It would be difficult for anyone out side a technician to find the problem. Thanks for asking and show all hands of support!
Jun 18, 2011 | Televison & Video
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
Televison & Video Logo
Top Televison & Video Experts
