Question about Tablets & eReaders
How to clear a fast reboot on a tablet - Tablets & eReaders
Take BATTERY out , Should then re set & re Start when battery replaced
Jan 06, 2016 | Samsung Galaxy TabPRO SM-T520 16 GB Tablet...
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
How do I fix my proscan tablet
What happens when you hit the internal reset button?
Jan 19, 2015 | Proscan 7-Inch Android Internet Tablet,...
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
My android tablet is stuck on android screen
Try Clearing the Cache by rebooting the device in Safe/Recovery Mode.
May 25, 2013 | Archos 7 Home Tablet Tablet Android 8 GB 7...
Keyboard dosent pop up all the time when i hit the enter button
Reboot the tablet for starters if you haven't and clear any cache for your keyboard application under settings > app > <keyboard app>
Dec 03, 2012 | Tablets & eReaders
Viewpia shutdown spontanious
Hi my problem is when i'm playing with the tablet it turn off automatic and it shows when an televishon had problems with a lot of colors and you can see anything it also gat battery low so fast .And when you plug it on it became to reboot s without any issues
Jul 17, 2012 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
