Question about GE Spectra JBP84 Electric Kitchen Range
Our oven is not heating up past 150 degrees. The
Our oven is not heating up past 150 degrees. The bottom heating element doesn't seem to be working - it doesn't turn red or even get hot to the touch at 425.
  • 11,896 Answers
The element will have to be replaced if there is no power going to it.
Posted on Jul 20, 2009
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Kenmore 790 oven won't heat after self clean
Did you fully disconnect the wires when you checked continuity? If not you are checking continuity in the whole circuit. For what its worth, the self clean feature superheats the oven and often burns out elements. We see it all the time. It is one feature to never use!
The broiler element is not part of the oven temperature, it is a broiler. The oven works on the bottom element alone. If it only gets to 300'F, wither the bottom element is faulty or the thermostat is failing. As I mentioned self clean is a great way to cause problems.
Nov 16, 2017 | Kitchen Ranges
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't heat past 150 degrees.
you either have a bad bake element or control. also check wiring between
Mar 25, 2010 | Kitchen Ranges
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Mer5755qab oven takes an hour to heat to 200
Either your bake element is bad or there is a bad connection going to the element. This is a very high current connection so bad connections are always a possiblity. Also check and make sure your broil element is working as some ovens use it for pre-heat. Do both elements seem about the same temp? You can turn the oven on and carefully hold your hand a few inches from the element to see if they are getting equally hot. If your connections are good to the elements then one of the "calrod" elements is probably bad. You can also check the resistance of each element. Not sure of exact reading but a higher resistance means less current going to the element. Just compare reading on each one and go from there. Good luck!
Mar 13, 2009 | Maytag MER5775Q Electric Kitchen Range
Open Questions:
See all GE Spectra JBP84 Electric Kitchen Range Questions
GE Spectra JBP84 Electric Kitchen Range Logo
368 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
