Question about Cell Phones
Good day i buy a second hand ice cub mashine it is an old mashine and their is a problem with the water float.
It is an Icematic N 180 M and i also need a manual i will appresiate it so much if you can assist me with one. Johannes from the Northen Cape Kimberley South Africa
3 Suggested Answers
bozcro
  • 867 Answers
SOURCE: broken gearbox
go through harley-davidson, sportster parts, same year.
Posted on Jun 19, 2009
SOURCE: I own a 1999 Audi A6 and the headlight lenses are
Unfortunatly, I don't have a solution to this problem, but I do have a similar problem. I have a 1999 Audi A6 Quattro and moisure is collecting inside the headlight. My lens are not clear anymore also.
Posted on Feb 16, 2010
How do you check the float needle in a cub cadet riding mower?
tank off bowl if fuel keeps coming out out on next take finger lift up float see if fuel stop next check float take it off shake buy yuor ear if you here gas in float bad float if not good
Aug 27, 2014 | Cub Cadet Garden
Icematic n131m
The more activity the freezer and fridge see, the more cold escapes. If the freezer defrost system gets issues (broken defrost heat coil, stopped up vents, frozen peas in coils) things slow down. Find the defrost timer and mark the knob on it with white-out to see if it moves. It moves very slowly, one rotation a day.
Nov 26, 2013 | Kitchen Appliances - Others
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have a Hoshizaki KM900MRH ice maker. It will run fine for a couple days then shut off and beep 3 times within 3 seconds. I am told by tech support that it could be a float switch. Where is the float...
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Icematic n201. water constantly flowing in over where ice is formed,i take it that shouldnt be happening when ice is being made. any suggestions?
Water is continuously pumped over the evaporator during the freeze cycle.When the machine enters the HARVEST cycle the purge valve opens dumping mineral laden water out the drain.
Jul 10, 2011 | Refrigerators
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hello everybody, I hope that you gona a give me some tips for repairing my dishwasher mashine. A few days ago, the error F2 appears on my dishwasher machine (Baucknecht GSI 5894) I checked the pump for...
Possible the inlet valve has given up and is not allowing water in.
Also possible there is a slight leak enough to shut the water off (safety feature) - Check underneath for a float mechanism and any water there.
Aug 20, 2010 | Bauknecht Dishwashers
I have an icematic n45s but it's not making ice and it was second hand so dont have the service manual. Does anyone know if there is anything i can do or do i need to get a repair guy out?
i have a icematic F120 and 2 of the 3 led`s are on (the no water led and too hi-loww cond temp 3`stand by) Does anyone know what is the problem.!?
Sep 18, 2009 | Freezers
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
