After cleaning filters and put them back on the wall mounted air conditioner, it seems all I get is 6 flashing lights.
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
Coldcut
  • 1554 Answers
SOURCE: Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Posted on Jun 13, 2008
SOURCE: Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Posted on Oct 07, 2008
  • 400 Answers
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Posted on Nov 19, 2009
  • 3074 Answers
SOURCE: White smoke coming from vent in room air conditioner
it sounds like it was humid which is normal for the cool air to mist, it will happen in your automobile ,also
Posted on Jul 24, 2010
Accessing filter in indoor wall mounted LG air conditioner R18AWN-NC9
You should just be able to pull the front up from either end. It just press fits on - finger tips either side - presumably a wall mount?
This will expose the filters which just slide out for easy cleaning. Make sure unit is off as it will blow all the dirt all over you.
Tap clean outside or hoover them.
Dec 01, 2016 | LG Heating & Cooling
Do i need to put water in my air conditioner it doesnt seem to b working like it should
Air conditioners don't need any water. Without more details, you should try cleaning the coils and the filter. It may also need freon.
May 26, 2014 | Fedders AED24E7F Wall/Window Air...
My portable air conditioner stops blowing cool air after a while and the light is flashing with a sign "lo" Does anyone know what this means?
Flashing lights are generally a sign of something wrong or something needs attention. Try emptying the water canister, cleaning the filters etc.. Not sure what LO means on your model. LO on some wall mounted splits means that the room temperature is below what the remote control can pick up.
Jul 03, 2011 | Heating & Cooling
Cleaned filter replaced it check filter light on
Hello
Is there a reset button on the control panel?
If not, try unpluging unit for a minute then plug back in to reset.
Apr 05, 2010 | Frigidaire FAC126P1 wall/window Air...
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Jun 12, 2008 | Heating & Cooling
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
