Question about Dishwashers
Installed dishwasher.Turned on noticed bottom of dishwasher full of water. turned on first time, water drained then e30 message came up. Have turned machine off and on, have turned water off and on.
  • 1462 Answers
SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
Posted on May 06, 2007
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
  • 3 Answers
SOURCE: Dishwasher won't drain all the way
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Posted on Dec 28, 2008
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher runs long.
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours, though many not included here still suffers from the same problem...you'll need the serial number too. Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning and obviously no "extra" heat ( aside from the water inlet temp. ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 03, 2011
news775
  • 699 Answers
SOURCE: after washing, water does not drain at bottom of
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 13, 2011
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
Dishwasher turned on accidently and full of water
Close the dishwasher door and run the drain cycle of the dishwasher only....that should empty the appliance. Note that a little bit of water remaining is normal, but if there is a substantial amount of water left, you will need to check the pump inlet screen and the drain hose or sink for any additional clogging.
Apr 02, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Pump running non stop.
On the left hand side of the dishwasher (looking from the front, open door) there is the water inlet port. Behind it is a float assembly that determines how much water is in the dishwasher and how much it needs to add or pump out.
If you pull the outside, panel, you will see that float assembly. Check for loose connection. Since you are getting no error codes, if everything looks OK, I recommend either schedule a service call or replace that assembly. If problems continue, the main controller board (PCB) is the next most probable cause.
Please report back with what you find. Thanks!
Apr 06, 2009 | LG LDF6810ST Stainless Steel Built-in...
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
No power to Selections, Water Did Not Drain
When you remove the bottom panel cover, check the wiring connection inside the junction box on the right for a loose or shorted wire.
If that's ok, open up the console and check the continuity of the thermal fuse that's clipped to the control board. Chances are it needs to be replaced.
Mar 05, 2009 | Dishwashers
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
Water not pumping into dishwasher
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Jan 06, 2009 | Dishwashers
Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
May 02, 2008 | Whirlpool 24 in. ADG6340iX Built-in...
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
