Question about Home
My Aqualisa Aquastream Thermostatic Power Shower has no power when I turn it on it is just the water pressure no motor running
3 Suggested Answers
  • 148 Answers
SOURCE: Our Aqualisa power shower lacks water pressure power
more than likely you have some debris near the shower head
take an adjustible wrench( crescent or channel lock
wrap a rag around the eustaceon( chrome tube coming out of shower wall srap around tube to protect the chrome hold it firmly with vicegrips or channel locks, take adjustible wrench or chanel locks and remove the chrome nut holding the shower head on to the eustaceon(turn counter cockwise be careful not to drop the tools that wil damage the tile or fiberglass
after removing showerhead
turn on shower to force and debris out and place shwoer head into stream of water to clean out any deposits the head may have some type of screen to strain the water
this should work if the flow has not incresed then there is a need to adjust the flow valve at the control
to reinstall the shower head reverse procedure
if you have any teflon tape wrap it around the threaded portion of the eustaceon
good luck
hoe this works
Posted on Dec 30, 2008
SOURCE: Aqualisa Aquastream shower noise from pump/motor ?
aquastuream loud noise?motor/pump
Posted on Sep 04, 2009
Aqualisa aquastream - when I turn it on the water pours down the wall. When turned off no trickle or leaks.
Surely something is leaking. I am attaching a diagram of the parts inside the unit for your reference. See if you can access the parts to find out which one is leaking and replace the broken part.
Feb 16, 2014 | Home
Tip
Power shower won't turn off
I thought this may be helpful as I have seen the same question a few times. A few days ago after my shower I turned the switch to off but the power motor was still running with water still coming out. I thought a new shower or at least an expensive call out. I looked up parts and decided to take a look and if needed replace a whole part or parts to save the call out costs.
the aqualisa is generally easy to dismantle as each part is substantial, if you are unsure look on their web site for the diagrams. This took me about 15 minutes and shower is working perfectly again and I was almost ready to replace parts or even a new shower at £400+. You will only need a cross head and a straight screwdriver.
-isolate the hot and cold supplies, and turn off the power.
- run the bathroom taps to reduce the water reassure and build up in the pipes.
- remove the front on/off dial
- remove the temperature control
- remove the front cover
- remove the black cover that clips over the main black cartridge, there is a black wire wrapped around the front holding the assembly in place so you have to remove the wire cluster that is secured on the right.
- you will see 4 torque screws holding the cartridge in place, these screws also have a straight screwdriver slot - loosen these, Be careful, there will be water and pressure still in the shower, allow this to spray out, it will gradually stop after about 30 seconds, now full remove the 4 screws.
- gently withdraw the cartridge
At the back of the cartridge is a small white water filter, check this and clear it, Mine was full of debris. Also check inside the recess as I found large lumps of grit from the water supply.
i believe the shower could not switch off as the grit and small debris had blocked the on off valve so water was still flowing and the pump therefore continued to run.
Now just assemble in he reverse order, turn the water supply and power on and the shower should work perfectly well.
After I realised that the turning off had felt different and it seemed to be spungy at the final bit of the turn off, I now realise this was the grit not allowing the mechanism to full close.
hope this helps someone.
on Jul 11, 2015 | Home
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Get a knocking noise from an Aqualisa Quartz 2
It may be a water hammering effect from pressure in your pipes. You may need to install a water hammer to stop this. you can put in line that will stop this.
Dec 28, 2009 | Home
Aqualisa quartz shower. Knocking / dripping type noise coming from pump when powered but not turned on. Any ideas???
this is caused by the water pressure in the pipes check that all the pipes are secured firmly this should stop the problem a piece of rubber or foam placed behind the pump will also help
Nov 15, 2009 | Home
Mar 30, 2009 | Home
On and Off control not fully working
I've never worked with an Aqualisa, but often times a problem like that is simply mineral build-up within the valve components. I would recommend turning the water off at the main and carefully disassembling the valve. Give it a good clean with some CLR and a toothpick. If the valve has any springs you may look into replacing them, as that is a common problem as well.
DO NOT forget to turn the water off at the main shutoff point, or you're gonna be in for the shower of your life once you take that valve out. You shouldn't need much besides a phillips screwdriver, and possibly an allen wrench and some pliers.
Mar 27, 2009 | Home
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
good luck
hoe this works
Dec 27, 2008 | Home
Getting handheld showerhead plus rainhead - which valve? - a pressure reliefvalve or thermostatic valve
I installed a 2 thermostatic valves in our shower. Two of us can use both showerheads simultaneously without being frozen or scalded.
Kind Regards,
IT_handyman
Oct 25, 2008 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Home Logo
91 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
