Question about Acer AL2016W 20" LCD Monitor
Hooking up a second ACER monitor as an extended desktop
I am adding a second ACER monitor to my Macintosh setup. I am having trouble getting an extended desktop. Currently I can only get a mirrored desktop (same image on both screens.
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Posted on Oct 08, 2008
Add monitor
to add a second monitor first make sure your laptop has a VGA connection (newer laptops have replaced these with HDMI or DVI, if you have these connections then use them)
now plug the VGA into the port, if the laptop is setup right it will pick it up automatically. if not you will have to do it yourself
so first right click on the desktop and go to screen resolution
in this new window there will be an option to either duplicate or extend with the choice of which monitor to use.
set it up how and as you wish if you are going for more than one screen it is recommended you buy a desktop with a graphics cards that supports up to 3 monitors
Jan 02, 2014 | Acer Aspire One D255 Laptop
Dual Monitor problems...
When you run multiple monitors in "extend" mode you will only get the icons and the "Start" button on one monitor. All it does is spread your desktop across both monitors.
Mar 23, 2012 | Computers & Internet
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
Hook netbook to tv with rca cables
after hooking it the TV we need to toogle to the external monitor.
Presentation or mirrored display mode
  1. Right-click an empty space on the desktop, and select Personalize .
  2. Select Display Settings
  3. When the New Display Detected dialog box appears, the images on both of the displays will be automatically mirrored.
  4. (Optional) To adjust the resolution, so that the display area of the monitors are the same size in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
The computer is now ready to display the same screen on all output devices, from monitors to projectors. Press the fn and f4 function keys at the same time to switch the image from the notebook display, to the external monitor, or to both. Extending the desktop
  3. Select the monitor representing your second display. Click the Extend the desktop onto this monitor checkbox and click OK . NOTE: To help identify your monitors, click Identify Monitors . The numbers 1 or 2 are shown on the monitor icons to help you identify them.
  4. (Optional) To adjust the resolution, in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
  5. (Optional) To change the direction the desktop will extend (left or right to match how the displays are physically set up), select a monitor and drag it to the desired position.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Does the Acer Aspire R1600 support extended desktop/dual monitors with the VGA and HDMI ports?
Yes it does. After hooking up the external monitor simply right click anywhere on the desktop, select properties, settings, and then change the monitor profile to your desired setting.
Good Luck,
NOLA Tech
Feb 05, 2010 | Computers & Internet
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
Extended monitor wont extend
can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
May 31, 2009 | Acer AL2016W 20" LCD Monitor
Extended desktop rotated, can't turn back.
Click on the extended monitor which is out of sync with the main monitor and click CTRL + ALT + UP
Thanks,
Vasu
Oct 02, 2008 | Microsoft Windows XP Home Edition
Trouble hooking external Viewsonic monitor to Toshiba laptop
If I understand You are using a Monitor connecting the Monitor...
and the background is shared byboth the display however the Cursor stays only on one of them at a time.However it can be toggled among the 2.
If yes,
then this Feature is called the Extended Display.
Use the same Key Combination that you would use for external Display one More time and it should Work.
Jul 03, 2008 | ViewSonic VX924 19" LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
