Question about Bissell Vacuums
47a2 bissell vacume - Bissell Vacuums
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
Hand held vacume stop working after 1st use
go please to the web for instructional videos and maintenance help
God bless you
Jul 19, 2012 | Bissell 3594 CleanView PowerTrak Bagless...
My Bissell power force vacum cleaner release peddle is broken causing the vacum to fall down my husband found that the attachment inside was broken how can I get a replacement.
The best thing to is to find a bissell dealer near you. most vacuums are covered under warranty and no one takes advantage of it instead they go out and spend money on something that could have been free. would be the best resourse for that.
Sep 18, 2011 | Bissell 3522 PowerForce Bagged Upright...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
Vacum bags
The vacuum that you have is over 10 years old. You can no longer get the bags directly from Bissell but if you call a authorized service center near you, they may still have bags that will fit your vac. So the answer to your question is yes....they use bags. Good luck!
Aug 03, 2009 | Bissell 3065 Power Partner Vacuum
I have the Bissell power force bagless upright vacume and I took the filters off and cleaned them and don't know where the round filter goes to be able to continue vacuming.
I had shortly after posting the question requesting help and then found the product manual.
Thank you very much though.
Jul 07, 2009 | Bissell Vacuums
My bissell will not **** water up
My bissell proheat cleaner will not vacume up water
Mar 02, 2009 | Bissell 1699 ProHeat Clear View Upright...
Target has replacement belts. In the manuel, it will tell you the size. 7-9-10 Drivebelt
Jan 03, 2009 | Bissell 3522 PowerForce Bagged Upright...
Vacuums Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
