Question about Building Materials
My Merlin garage door has just stopped working. turned off at power and back on. Light works but the door still doesnt open
TJBENGR
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Posted on Apr 14, 2010
swolfinor
  • 504 Answers
SOURCE: 2006 GMC Envoy Denali, Universal Garage door
GOTO HOMELINK.COM TO DOWNLOAD INSTRUCTIONS FOR THIS SYSTEM
YOU WILL NEED TO RE PROGRAM THE UNIT WITH YOUR DOOR OPENER.
HOPE THIS HELPS
Posted on Feb 10, 2011
  • 3197 Answers
SOURCE: My Chamberlain Liftmaster Formula 1
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Posted on Jun 13, 2011
I have 2 Merlin MR800 garage doors operating side by side. 1 door stopped working with the remote, however it WILL open the door if you hold it right next to the unit.
What kind of light bulbs are you using? I know it sounds crazy but the new LED and the old CFL can interfere with the range of the transmitter by blocking the signal to the receiver
Mar 21, 2016 | Building Materials
Merlin M802 remote not working it has a new battery and the red light flashes when button pressed but won't open or close the door
need to reprogram it to the opener. push the 'learn button' then push the remotes button. door should then respond.
Dec 22, 2015 | Building Materials
The light stays on
guessing it is a sensor issue. the safety sensors
Aug 23, 2015 | Building Materials
How to program a remote control for Merlin Garage Door
Each manufacturer of aftermarket remotes for Overhead doors has a specific sequence for a specific door opener mfg and model #. And those sequences are include in the printed matter in the packaging of the remote. If you have Merlin remote and Merlin opener contact the local Merlin installer for the sequence.
Oct 13, 2014 | Building Materials
I have a Merlin Powerlift 2500L that opens and stops half way. When disconnected from the door, the release rod travels the proper distance. However, when the door is connected, its upward movement stops...
Release the door from the opener and operate it by hand. Check for binding and excess heaviness of door. You may also need to increase the up force. Heaven only knows where it is on a Merlin.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin 230T garage door opener which abruptly stopped working altogether. Could it be the fuse?--or any other suggestions.
There is a fuse in a Model M-230T and I have seen a service man change it.Now that the fuse has blown again, I want to change it myself BUT can't now find it!
Can anyone please offer a guide to changing the fuse?
Sep 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote code for a merlin power lift
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door starts and stops immediately i sprayed the tracks and it worked for about a week but now it's back to starting and stop[ng prematurely
With most garage door openers, you can look under the light bulb cover and you'll find two numbered knobs. These knobs set the motor torque/speed ratio. Basically, if the door is really smooth having the knob turned down will make the motor go faster. Turning the knob up will give the motor move "oomp" but it will move a little slower. One knob adjusts the power going up and the other knob adjusts the power going down. This basically depends on how good the springs are working on the door itself. So just adjust the knobs until the motor is running each direction "comfortably".
Nov 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
66 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
