Question about Building Materials
Hi,I have a Merlin garage door which has just stopped working. Does not work from either controls. I have turned off at power.
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 3197 Answers
SOURCE: Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Posted on Nov 21, 2009
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Posted on Apr 14, 2010
  • 3197 Answers
SOURCE: My Chamberlain Liftmaster Formula 1
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Posted on Jun 13, 2011
I have 2 Merlin MR800 garage doors operating side by side. 1 door stopped working with the remote, however it WILL open the door if you hold it right next to the unit.
What kind of light bulbs are you using? I know it sounds crazy but the new LED and the old CFL can interfere with the range of the transmitter by blocking the signal to the receiver
Mar 21, 2016 | Building Materials
Merlin door opener remote stopped working
Check to see if there is a small battery inside could be weak or bad if so will have to reprogram the remote again
Mar 16, 2015 | Building Materials
How to program a remote control for Merlin Garage Door
Each manufacturer of aftermarket remotes for Overhead doors has a specific sequence for a specific door opener mfg and model #. And those sequences are include in the printed matter in the packaging of the remote. If you have Merlin remote and Merlin opener contact the local Merlin installer for the sequence.
Oct 13, 2014 | Building Materials
I cant get the remote control for a Merlin garage door to program, 2 new remotes 2 new batteries.
go to manufacturer website and contact them for a detailed step by step procedure, ask any school child to help you with programming the electronics, call a garage door specialist to come program it for you.
Sep 20, 2014 | Building Materials
Merlin 230t
If the chain is loose I would definitely tighten it up to remove the sloppiness of the drive. That will in turn help you to accurately find the sweet spot that is currently eluding you. And you have to work fast because you do not want to overheat the motor.
Sep 21, 2017 | Sears Craftsman LiftMaster Chamberlain...
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
I have a Merlin Powerlift 2500L that opens and stops half way. When disconnected from the door, the release rod travels the proper distance. However, when the door is connected, its upward movement stops...
Release the door from the opener and operate it by hand. Check for binding and excess heaviness of door. You may also need to increase the up force. Heaven only knows where it is on a Merlin.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin 230T garage door opener which abruptly stopped working altogether. Could it be the fuse?--or any other suggestions.
There is a fuse in a Model M-230T and I have seen a service man change it.Now that the fuse has blown again, I want to change it myself BUT can't now find it!
Can anyone please offer a guide to changing the fuse?
Sep 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need a code for a 12 pin remote control unit for a merlin power lift garage door the model is 4000 model 1/3HP 240V.AC Is it on the door anywhere. Thankyou
These are available on the internet. If you were to go to google and enter in the information you would find a lot of sites, even ebay. Chamberlain does make an universal remote called a clicker that will program to this too, Thanks BB
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote code for a merlin power lift
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
66 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
