Question about Plumbing
Is the retaining nut in faucet big metal one around outside smaller plastic one inside
fanny
  • 146 Answers
SOURCE: Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Posted on Nov 09, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Posted on Feb 12, 2009
  • 659 Answers
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Posted on Apr 10, 2009
gary1121
  • 332 Answers
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
  • 21 Answers
SOURCE: how to remove retaining nut on two handle faucet
sounds like you need a basin wrench that is made for taking off nuts like this one.  you can find one at local hardware store.
Posted on Jun 21, 2009
How do remove the faucet cover of a moen 7594EC
MOEN Motionsense Faucet Leaking????
Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
Screw the nut back into place with your hand, then tighten with a wrench.
Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
My kitchen sink sprayer is leaking when the faucet is on, but the sprayer is not engaged. How do you repair it?
It can be one of two things. It could be the spray divertor located on the post of the faucet. For a basic Moen Kitch faucet you must remove the handle. With older faucets simply pull up to slide off the hdle cap, unscrew the center screw that holds a black plastic retainer cap, to remove cap, disengage it by lifting handle. Now remove the metal, grooved retainer nut by unscrewing. You can now slide off the spout. You will see a white cylindrical ring which is wider at the base, and has two o-rings. This is the divertor.Slide it off. The part # is Moen 91192. Apply faucet grease or silicone grease to the o-rings exposed on the faucet post as well as on the inside of the new divertor. Slide the div. back on and reassemble in reverse order. If this doesn't work, just replace the sprayer head. Unscrew the head from the nut at the bottom of the head. You will find two gaskets. Remove them from the grooved plastic nipple and make note of which one goes on first. The plastic nipple has a lock ring, a "C" shaped piece of metal set in a groove on the nipple. Remove the ring using a small screw driver. This can be a little tricky. Do not damage the plastic, and don't lose the lock ring.. Now you can remove the bottom of the head. Replacements come in various styles and colors, so pick one suited to your tastes. Now reverse the process. and you have a new head. Good luck!
Sep 03, 2013 | Moen & One Handle Tub & Shower Faucet
How to replace hansgrohe M2 cartridge
First you will need to tighten the set screw all the way back in. The use your 4mm hex wrench to turn the screw 4 complete turns counter clockwise. Then remove your hex wrench and the handle should come off. There will be a dome shaped cover with blue and red indicator marks. This will simply pull off the cartridge nut. It is held on by o-ring tension only. Once removed you will see the large hex head of the cartridge retainer nut. Loosen this nut and the nut and cartridge will come out of the faucet. Don't be alarmed if your new cartridge is smaller than your old one. There has been a design change in the cartridge so it will fit smaller bodied faucets but will still replace the older thicker cartidge. If you need any further information feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be glad to help.
Aug 04, 2012 | Hansgrohe Plumbing
Blanco Supreme 533-U sink drain leaking at seal
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Jan 15, 2012 | Plumbing
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    The faucet is loose in the sink mounting hole and it cannot rotate.
    This is a very expensive faucet-- with almost TOO MUCH STUFF trying to get thru the retaining nut under the sink! The person installing this faucet likely had a 'nightmare' getting all the pipes thru that little hole, and getting the nut and washer to fasten to something solidly!
    Have you looked up under the sink, to see what it will take to tighten the large nut around that main faucet body?
    Likely your sink restricts contact with normal slip joint pliers, and most Basin wrenches are not big enough to get around that large retaining nut.-- Thus the problems since this faucet was first installed!
    So-- Your goal is to get the nut to tighten solidly, and prevent the stationary body from rotating when you try to swing the spout.
    NOW-- If the spout has 'frozen' in the vertical tube inside the pivot point, then this has to be dismantled first. Do you have a good parts supply nearby?
    Because you might need some 'order only' parts to make this repair--
    I suggest you take the make and model numbers (that you supplied us)-- and go to the hardware/plumbing section of the plumbing and faucet supply store you trust-- One that can open a book to a nice big parts blow up of this faucet-- tell him your problem,and see what parts he suggests they order for you-- When they come in, then your work begins!
    The parts guy should be able to help you get the right wrench, to tighten this faucet up in that tight spot, too!
    May your back be strong, as you work upside down in cramped quarters for a good long day! :-)
    Let us know if we can help more-
    Mack B
    Jan 27, 2011 | Blanco 157-075R-BT Elan II Kitchen Faucet...
    How remove the broken bathtub cartridge(Moen 1222)
    The exact procedure to remove the old cartridge is with a plastic removal tool.With replacement cartridge you have to buy this plastic removal tool.Also there is same metal removal tool available.With the help of this tool you can easily remove the old cartridge.
    Moen Cartridge Replacement Instructions
    Moen shower faucet cartridge replacement is a project that will take some time to get done right. When is it time to replace a Moen cartridge? If you are like most people, you won't want to replace your old Moen cartridge until your old cartridge is starting to show its age.
    Replacement is necessary, usually, once the old faucet starts to drip. Thankfully Moen faucet cartridge replacement is not difficult. However, if you are uncomfortable with doing the repair yourself, do not hesitate to call a professional plumber to do the job for you. This will guarantee that the job is done right.
    If you follow these Moen faucet cartridge replacement instructions you will be able to replace your old cartridge by yourself. First of all, as with any plumbing repair, make sure that the water supply is turned off. Open the faucet to remove water pressure from the lines and let the remaining water drain from the pipes. You will then need to remove the faucet's handle by removing the decorative cover and removing the retaining screw. This will allow you to remove the handle.
    Once the handle has been removed, work on releasing the splash plate from the wall. Generally there will be one or two screws to remove and the plate should release from the wall easily. From here the process begins to get a little trickier. Insert a shower stem socket onto the faucet valve's retaining nut and release the nut. Your Moen cartridge removal will be complete once you grab the cartridge with a pair of pliers and pull straight out to remove the old cartridge.
    Clean any surfaces that you have access to and replace with the new cartridge. Follow all of the previous instructions in reverse order to re-assemble your shower faucet. Check to make sure that all the connections are tight before turning the water back on and testing the system out.
    Now in your case the broken/cracked while removing the old cartridge so try this procedure carefully to get the stuck -up old cartridge out.
    TAPPING the Threads into the Cartridge:
    Carefully  hold one tab on the cartridge tight against the brass lip on the faucet body with needle nose and try  to drive the 1/2" tap into the smaller bore of the cartridge. It will take  about 15 minutes to slowly work the tap in all the way (maybe 3 turns?). Then  back out the tap... remove needle nose. [remember to turn the tap 1/4 turn back, for each 1/2 turn forward ... this clears the metal particles from the tap and makes the next 1/2 turn forward go smoother].
    Next, assemble a 1/2" x 4" threaded rod, so it had threads all the way to the two jam nuts on one end)... If you use a bolt, get one with threads all the way up to the head. you may find it hard to find - so try a carriage bolt and spin a nut all the way up to the head .... continue:
    next on the bolt goes a 1/2 nut (this is the "jacking nut") and a flat washer so the jacking nut can spin easily against the next piece, a 1/2 drive socket (7/8" ) with the square hole toward the washer and jam nuts ( bolt head ).
    The open end of the socket faces the brass body of faucet and rests on the round brass lip... having the same inside diameter. This allows a space for the cartridge to be pulled into ( a cavity). Thread the bolt into the tapped cartridge and snug it up so the 7/8" socket is aligned with and resting against the brass body. If the cartridge spins smooth, the threaded rod is GREAT. You can just work with the 1/2" rod and use needle nose (or similar) to stop the  cartridge from spinning, to get the rod threaded into the tapped threads in the cartridge... then, slip on the socket, washer and nuts.
    Now snug it up tighter. Check socket alignment. Then begin turning the jacking nut ( the "extra" nut) until it contacts the flat washer and 7/8" socket. Now, as you continue to tighten the jacking nut, it will pull the 1/2 bolt (threaded rod) away from the faucet... and the cartridge will come along too. [You have to prevent the 1/2 rod from spinning while tightening the jacking nut. put a wrench on the bolt head.]
    This procedure is bit lengthy and requires some appropriate tools,but this will release the stuck cartridge out.
    Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
    Jun 05, 2010 | Moen & One Handle Tub & Shower Faucet
    May 30, 2009 | Blanco Classic Single Handle Faucet with...
    How do I get the cartridge out of Kohler kitchen faucet Coralais
    You have to remove the "large" nut but you need to find a way to hold the faucet. Also, you will see a retaining washer that fits on the inside of that "large" nut. If you loosen this it will release some of the tention on it and hopefull make it easier to remove. Also, try using some lime remover on the unit will might alow the retaining nut to loosen. Good luck and if you can't get it off, contact Kohler, they have an 800 number and they can give you the info you will need depending on your model.
    Mar 29, 2009 | Kohler Plumbing
    Plumbing Logo
    83 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
